08-06-2010, 12:17 PM #1
Hoover Nextra fridge not cooling correctly
Hi all, hope I can provide enough useful information.
I have a Hoover Nextra (frost free) fridge freezer which is about five years old now, the fridge is controlled by a dial which goes from 1 to 5 (where 5 is 'super' and intended for when you go on holiday) and I leave set to 3.
Recently, however, the fridge doesn't seem to be cooling as well as normal and particuarly sensitive things like cream have been going off. The freezer seems no different, but I've had to crank the fridge up to 5, the maxium setting, just to keep everything cool (and a little ice builds up at the back).
The pipe where the water is drained is visible at the back of the fridge, and at least the part I can see looks fine. I also moved the fridge out slightly incase it had been pushed in and didn't have enough space to cool at the back.
Is there anything obvious I should be checking, or is five years a good life and I should be replacing it about now?
08-06-2010, 03:50 PM #2
Re: Hoover Nextra fridge not cooling correctly
hi quitch, can you hear the compressor , buzzing? dose the light work ? has the fuse gone? after that you may have to get someone in .
age of a fridge 5- 10 years you could be unlucky,
08-06-2010, 05:05 PM #3
check the gas on it
Hoover VCN6185 E1 Fault code fridge warm freezer frosting ?
By Ronnie in forum DomesticReplies: 7Last Post: 15-01-2010, 12:58 PM -
bypass a pcb on hoover nextra fridge freezer
By shrewey in forum ElectricalReplies: 0Last Post: 29-07-2009, 03:30 PM -
crazy 3rd-world idea: aircon from small fridge
By lsemprini in forum FundamentalsReplies: 71Last Post: 29-05-2008, 01:10 AM -
Hotpoint Future Fridge Cooling Problem
By Stoksey in forum DomesticReplies: 10Last Post: 26-01-2008, 07:42 PM -
fridge freezer cooling fan
By bazza in forum Trouble ShootingReplies: 4Last Post: 28-02-2007, 11:33 PM
