Results 1 to 1 of 1
Thread: Pilot operated bypass
08-06-2010, 11:27 AM #1
Guys, I'm pretty new in here...I have a system where there is a pilot operated solenoid valve fitted as a bypass between evaporator inlet and outlet..the pilot line is led from the expansion valve before the evap..any ideas why such a solenoid valve?? I feel that this bypass valve could result in liquid refrigerant coming to the compressor suction...whadya all think ???
What do you think of 2 DX type AHUs sharing the same condensing unit?? Any special care to be taken when one AHU is not running?
Chilled water bypass problem
By MACT in forum Trouble ShootingReplies: 5Last Post: 16-10-2008, 02:01 AM -
Hot Gas Bypass (HGBP)
By CoolKids in forum Air ConditioningReplies: 15Last Post: 20-06-2008, 05:42 AM -
old system with hot gas bypass. help!
By joapysoe in forum Trouble ShootingReplies: 8Last Post: 20-01-2008, 11:58 PM -
Hot gas bypass control?
By Jase in forum Air ConditioningReplies: 9Last Post: 29-10-2006, 11:21 AM -
The Photographer And The Pilot
By chillin out in forum Chit Chat & Service StoriesReplies: 7Last Post: 29-01-2006, 09:50 AM
