Thread: Smartcool concept
08-06-2010, 10:52 AM #1
Smartcool concept
Any ideas on how the Smartcool ECO3 system works? Is it just a question of raising the evaporation temperature?
thanks!
08-06-2010, 03:12 PM #2
Re: Smartcool concept
Higher suction pressure will reduce TD and compressor should run longer. Another "magic" black box. There is no magic in refrigeration.
08-06-2010, 11:13 PM #3
Do a forum search on Smartcool, there have been previous discussions on this snake oil product.
03-07-2010, 08:48 PM #4
its just like a magic box which can solve ur problems and can amke ur instument or equipment the best one....you can use it anf i am sure you will feel the difference...
07-07-2010, 08:25 PM #5
Actually there aint much on here, so this is what i reckon..
I think it all works on the rate of change of pressure.
If the pressure is rising, and the controller wants to bring on a stage - then the device looks at the rate of change of pressure - if its not rising very fast, then it may stop a compressor from starting for a while..
It may also do somthing to stop compressors running on if the pressure is at of below the setpoint, but the controller is still calling for a compressor, ie force a stage off before the controller wants it too..
I'm not 100% convinced it works though, it reckon in the end it just ends up fighting against the controller.
07-07-2010, 09:23 PM #6
12-07-2010, 04:15 AM #7
It's not doing anything our current systems already do. I see on there test they used ASDA in the UK and the baseline information wasn't accurate so they extrapolated the base data. I am the Refrigeration project manager for Walmarts home office and our current EMS systems already run enhanced suction control and floating suction strategies that do the same thing. This is an add on box of snack oil.
Smartcool Products - Do they really work?
By curiousgeorge in forum New TechnologiesReplies: 10Last Post: 19-05-2010, 07:13 PM -
Third world refrigeration concept
By MarkMurray in forum RefrigerantsReplies: 0Last Post: 09-02-2010, 10:29 AM -
Ice Dispenser --New concept of ICE MAKER
By osion in forum CommercialReplies: 9Last Post: 04-01-2010, 08:44 AM -
Smartcool
By Keef_Controls in forum Supermarket RefrigerationReplies: 2Last Post: 23-09-2009, 09:20 AM -
Top Entry/ Bottom Entry concept for plate freezers
By smpsmp45 in forum NH3Replies: 28Last Post: 19-06-2008, 04:37 PM
