07-06-2010, 09:51 AM #1
Recommend electronic leak detectors
Hi guys, can anyone recommend a good affordable electronic leak detector? I had one years ago but as soon as you you were within view of the unit or walked through the door of a cold room it would start beeping uncontrollably even though you've used soapy water on every inch of pipe and joint on the unit. I've seen a few advertised but they range in price from £50 - £400, Would i be wasting my money going for one around £150 mark?
Thanks guys. Appreciate your help and advice.
07-06-2010, 10:09 PM #2
Re: Recommend electronic leak detectors
I always had the same problem to the point where I gave up on electronic leak detectors.
Then I got a Yokogawa which was good but bulky.
Now have a Javac D tek select, was lucky enough to get it on a special at D&W @ £235 + VAT.
I can honestly say it is the only electronic leak detector that I have used that I would rely on.
It finds leaks that soap solution confirms with just the finest micro bubbles!
Try and buy the best you can.
Regards,
djbe.
07-06-2010, 11:20 PM #3
Thanks DJ I'll have a look into that one for sure. I gave up on them about 10 years ago but I'm thinking they must be better by now lol.
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
Leak detectors
By Temprite in forum Tools and CalculatorsReplies: 54Last Post: 18-08-2010, 04:15 PM -
Electronic leak detectors
By CHIZEL010 in forum Tools and CalculatorsReplies: 8Last Post: 22-11-2008, 04:46 PM -
leak detectors
By martinw58 in forum HydrocarbonsReplies: 9Last Post: 12-04-2008, 04:34 PM -
Electronic Leak Detectors
By Freecool in forum Tools and CalculatorsReplies: 27Last Post: 03-04-2008, 09:04 AM
