    Feb 2010
    Scotland
    28
    Question Recommend electronic leak detectors
    Hi guys, can anyone recommend a good affordable electronic leak detector? I had one years ago but as soon as you you were within view of the unit or walked through the door of a cold room it would start beeping uncontrollably even though you've used soapy water on every inch of pipe and joint on the unit. I've seen a few advertised but they range in price from £50 - £400, Would i be wasting my money going for one around £150 mark?
    Thanks guys. Appreciate your help and advice.
    Dec 2004
    U.K
    55
    518
    21
    Re: Recommend electronic leak detectors
    Quote Originally Posted by gio_ayr View Post
    I always had the same problem to the point where I gave up on electronic leak detectors.
    Then I got a Yokogawa which was good but bulky.
    Now have a Javac D tek select, was lucky enough to get it on a special at D&W @ £235 + VAT.
    I can honestly say it is the only electronic leak detector that I have used that I would rely on.
    It finds leaks that soap solution confirms with just the finest micro bubbles!
    Try and buy the best you can.
    Regards,
    djbe.
    Feb 2010
    Scotland
    28
    Thanks DJ I'll have a look into that one for sure. I gave up on them about 10 years ago but I'm thinking they must be better by now lol.
  1. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  2. Leak detectors
    By Temprite in forum Tools and Calculators
    Last Post: 18-08-2010, 04:15 PM
  3. Electronic leak detectors
    By CHIZEL010 in forum Tools and Calculators
    Last Post: 22-11-2008, 04:46 PM
  4. leak detectors
    By martinw58 in forum Hydrocarbons
    Last Post: 12-04-2008, 04:34 PM
  5. Electronic Leak Detectors
    By Freecool in forum Tools and Calculators
    Last Post: 03-04-2008, 09:04 AM
Tags for this Thread
