Threaded View
06-06-2010, 09:13 PM #1
Pressure differential valve selecting
How do you select pressure differential valve?
For example it's Danfoss NRD, Sporlan ORD...
Danfoss don't say the calculation of determine quantity of NRD.
Sporlan gives:
In those cases where the ORI-10 is applied on systems with more capacity than the ORD-4
or when more than one head pressure control valve is
used, it is necessary to use two or more ORD-4 valves in parallel.In some places will have to think ...
discharge pressure relife valve opening
By govindarajan in forum Trouble ShootingReplies: 10Last Post: 05-05-2010, 11:26 AM -
Relief Valve Sizing
By GBRD in forum IndustrialReplies: 6Last Post: 16-04-2010, 04:00 AM -
Pressure differential across air conditioned rooms
By Rabindra in forum Air ConditioningReplies: 9Last Post: 25-10-2007, 09:30 AM -
Back Pressure Valve
By guapo in forum Industrial CompressorsReplies: 2Last Post: 18-03-2006, 04:38 PM -
Pressure, Vacuum and Differential
By HVACGod in forum Air ConditioningReplies: 0Last Post: 01-11-2005, 03:22 AM
