Results 1 to 2 of 2
Thread: daewoo frs2032ibe water leak
06-06-2010, 04:30 PM #1
Can someone please advise how to gain access to the water feed pipe to the despenser of my Daewoo FRS2032. I have a water leak running down the feed pipe inside the left hand side door. I need to gain access inside the door but it looks sealed tight. All help gladly excepted
Thanks jim
04-07-2010, 11:17 AM #2
Re: daewoo frs2032ibe water leak
had same problem for years. Dont suppose you found a soution? I've taken the front panel off but still cant seem to get at the dispenser pipe.
I've heard it may be the solenoid not shutting properly, but dont know how to access it.
ta
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
Cleaning water circuit after a refrigerant leak
By wingman in forum Air ConditioningReplies: 4Last Post: 15-05-2009, 09:16 AM -
evaporater leak
By jebar in forum Trouble ShootingReplies: 2Last Post: 07-04-2009, 03:56 AM -
pure water from air
By Lc_shi in forum New TechnologiesReplies: 32Last Post: 26-02-2009, 12:25 PM -
Building a wine cabinet
