05-06-2010, 03:50 AM #1
Ice build up on the air conditioning high side
hi
just had a samsug mini split installed. worked fine for about 2 days. when i turned on the unit for about 5 minutes i noticed that it was only blowing hot air, when i check the out side unit the small copper line was covered in ice the bigger copper line was warm. i turned the unit off for about 10 minutes and then on again it did the same thing. what could be causing this problem.
thanks for your help
05-06-2010, 05:30 AM #2
Re: Ice build up on the air conditioning high side
system is undercharge ckeck for leakage.check for trace of oil on the tail.between evap and condenser pipework.and all flarenut.All the best.
05-06-2010, 04:16 PM #3
Get the installers back to check it over.
05-06-2010, 07:30 PM #4
Thank you I checked it and there is a leak thank you
Side by Side TPG21PRXFBB
By michel_engelen in forum DomesticReplies: 2Last Post: 26-05-2010, 08:57 AM -
Vac Down Procedure.
By mendoza in forum FundamentalsReplies: 3Last Post: 26-09-2009, 04:19 PM -
A/C Pressure problem - Low side too high
By Acrisoft in forum Air ConditioningReplies: 7Last Post: 17-09-2009, 12:14 PM -
samsung side by side sr-s2028css
By sork in forum Technical DiscussionsReplies: 2Last Post: 26-06-2008, 09:06 PM -
Pressure relief valve
By DaBit in forum FundamentalsReplies: 18Last Post: 16-08-2003, 03:11 PM
