Thread: Daikin inverter problems
03-06-2010, 09:41 PM #1
Hi guys this is my 1st post although i've been a member for sometime.
I have a inverter problem on a daikin Rsey8gk7w1 unit, fault code (L0) on controller. can anyone point me in the direction of the techincal manual, i've had a look on the daikin site but can't find this unit.
It's a 14years R22 unit.
03-06-2010, 10:45 PM #2
Re: Daikin inverter problems
Hey first time to post so go easy on me. I have had this fault many times on thoes old 22 invertets it's either the inverter board or the compressor or the big White resister top left corner of the inverter board.if u check the resister with a meter and it's ok Disconnect the inverter compressor and try reset it if the fault clears u need a new compressor. If it doesn't change the inverter board u will prob need a new compressor too. Hope iv bein some help.
04-06-2010, 09:26 AM #3
Try this link
http://extranet.daikin.co.uk Just sign up and help yourself
http://www.daikinac.com/commercial/home.asp?
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
daikin L0 inverter problem
By robin r33 gtr in forum Air ConditioningReplies: 17Last Post: 11-03-2010, 11:25 PM -
Daikin Inverter board failures
By Greengrocer in forum Air ConditioningReplies: 10Last Post: 21-05-2009, 04:35 PM -
Daikin Inverter Board / Compressor issues
By Greengrocer in forum Air ConditioningReplies: 12Last Post: 21-04-2009, 10:12 PM -
Daikin Comp and inverter
By WCC73 in forum Air ConditioningReplies: 5Last Post: 08-11-2008, 08:44 PM
