03-06-2010, 02:56 PM #1
Hotpoint Mistral Displaying wrong temp for freezer
Hi - lady in distress!
I have a Hotpoint Mistral fridge freezer - having thrown away food before thinking it had defrosted and frozen again I now discover that the two freestanding thermometers I have put in the freezer both register lower than -30 degrees - the food also is quite frozen - BUT the display at the top of the freezer is telling me at diffrerent times of day anything between +14 to +4 at the moment.
The fridge temp is fine - had a thermistor about 18 months ago replaced for that as fridge was freezing everthing. Should I worry or just ignore the temperature display from now on? This has happened 3 times now - the previous two I turned it off for a few days as advised by a friend and chucked the contents - as it is not my main fridge freezer it is a problem but not critical. Anyone got any suggestions or had this problem before? Apart from these episodes it works fine the rest of the time. Thanks in anticipation of a reply with the solution.
04-06-2010, 06:55 AM #2
Re: Hotpoint Mistral Displaying wrong temp for freezer
If you don't want to repair/spend on it you could buy a thermometer especially for a freezer which has a wired sensor and an audible alarm.just clamps to the side or top and the sensor goes inmate the freezer.http://fridge-freezer-alarm.co.uk/ may have something,tons available on net.
BGLast edited by spimps; 04-06-2010 at 06:59 AM.
09-06-2010, 05:05 PM #3
change thermistors common thing and cheap and easy to do.
domestic problems- hotpoint mistral fridge/freezer
By Northdude in forum DomesticReplies: 49Last Post: 02-10-2011, 08:21 PM -
Hotpoint Mistral Plus - freezer temp intermittantly goes above freezing!
By robinsmh in forum DomesticReplies: 0Last Post: 22-10-2009, 01:31 PM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
By Bobby Ewing in forum DomesticReplies: 5Last Post: 05-01-2008, 11:35 AM
