    sme22's Avatar
    sme22 Guest
    Unhappy Hotpoint Mistral Displaying wrong temp for freezer
    Hi - lady in distress!
    I have a Hotpoint Mistral fridge freezer - having thrown away food before thinking it had defrosted and frozen again I now discover that the two freestanding thermometers I have put in the freezer both register lower than -30 degrees - the food also is quite frozen - BUT the display at the top of the freezer is telling me at diffrerent times of day anything between +14 to +4 at the moment.
    The fridge temp is fine - had a thermistor about 18 months ago replaced for that as fridge was freezing everthing. Should I worry or just ignore the temperature display from now on? This has happened 3 times now - the previous two I turned it off for a few days as advised by a friend and chucked the contents - as it is not my main fridge freezer it is a problem but not critical. Anyone got any suggestions or had this problem before? Apart from these episodes it works fine the rest of the time. Thanks in anticipation of a reply with the solution.
    Sep 2008
    Letsby Avenue
    359
    Re: Hotpoint Mistral Displaying wrong temp for freezer
    If you don't want to repair/spend on it you could buy a thermometer especially for a freezer which has a wired sensor and an audible alarm.just clamps to the side or top and the sensor goes inmate the freezer.http://fridge-freezer-alarm.co.uk/ may have something,tons available on net.
    BG
    Jun 2010
    change thermistors common thing and cheap and easy to do.
  1. Replies: 49
    Last Post: 02-10-2011, 08:21 PM
  2. Replies: 0
    Last Post: 22-10-2009, 01:31 PM
  3. Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
    By sumnerpa in forum Trouble Shooting
    Last Post: 19-08-2008, 03:16 PM
  4. Compressor loading, cooling, and range of operation.
  5. Hotpoint Mistral Plus
    By Bobby Ewing in forum Domestic
    Last Post: 05-01-2008, 11:35 AM
Tags for this Thread
