Thread: temperature in freezer
02-06-2010, 10:11 PM #1
Hello guys!
going to have my final exam in a few days.
Considering that I have gone to school for almost a year now, this is probably a lame question.
I have mounted a freezer/ freezing room (not sure what it's called in english)
So I just had to be sure if the right temperature is -18 degrees celcius or if it is -22 degrees celsius?
Thanks in advance!
02-06-2010, 11:15 PM #2
Re: temperature in freezer
The temperature can be whatever you desire.
Normal domestic frozen food should be stored at no warmer than -18°C, commercial stores may go for -22°C or beyond.
It does depend on the product that you are storing.Brian - Newton Abbot, Devon, UK
03-06-2010, 06:09 AM #3
Sometimes local regulations gives you the temperature.
In Belgium, frozen goods must be kept at a temperature >-18°C, so with -22°C, you have some safety margin.
If temperature goes higher then -18°C, then an alarm has to be triggered after a certain waiting time for every freezer larger than 10m³ (for Belgium) Temperature must also be recorded at least every 15 minutes with an automatic recording (again for freezers >10m³)It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
03-06-2010, 03:27 PM #4
Allright, thanks guys!
Superheat and Subcooling
LG heat pump problem
By back2space in forum Heat PumpsReplies: 132Last Post: 01-02-2009, 11:23 PM -
TK basic micro-p features and functions
By REEFER-TEK in forum TransportReplies: 0Last Post: 05-12-2007, 06:25 PM -
Article in ACH&R News
By Gary in forum FundamentalsReplies: 8Last Post: 20-05-2003, 12:27 AM
