31-05-2010, 04:43 AM #1
Cleaning tubes in Shell and tube condenser
Does anyone know the procedure to clean the copper tubes of a shell and tube water cooled heat exchanger?
what cleaning agents should I use?
31-05-2010, 05:41 AM #2
Re: Cleaning tubes in Shell and tube condenser
Hi there,
The cleaning agent is Hydrochloric Acid with 10% concentration.
Commercial de-scaling agents usually contain corrosion inhibiting agents.
Be careful, copper inhibiting agents are very corrosive with galvanized steel. Separate the copper pipework from the steel piping.
You have to use a tank with a pump and circulate the solution through the condenser. When de-scaling is complete then circulate some kind of alkaline solution to neutralize the acid. After that circulate water to clean the remaining residue.
CheersEven Einstein Asked Questions
31-05-2010, 10:50 PM #3
Thank you lana.
Parallel condensers Shell and tube paralle with Evaporative Condenser
By Herschmidt in forum NH3Replies: 2Last Post: 08-06-2010, 11:12 PM -
Chemical Cleaning on fouled tubes
By jayaeros in forum Air ConditioningReplies: 1Last Post: 09-09-2009, 06:00 PM -
Fabrication of Cooler Tube & Shell Cooler
By rickyccong in forum Technical DiscussionsReplies: 1Last Post: 27-07-2009, 02:25 PM -
Water velocity in Shell and tube HE
By wilsoncheung in forum IndustrialReplies: 15Last Post: 07-04-2009, 07:59 PM -
liquid level in Shell and Tube flooded evaporators
By cygbob in forum NH3Replies: 3Last Post: 09-09-2008, 04:33 AM
