Results 1 to 8 of 8
    Mar 2004
    Denmark
    65
    21
    Eroding in pipe heat exchangers
    I use liquid/gas pipe heat exchangers in some cooling systems. somebody has told me that if the gas speed is 20 m/sec. or higher,
    it will cause eroding in the pipes.
    I know water and other liquids can cause eroding, but with a clean refrigerant on both sides of the heat exchangers and a oil film to protect the pipes, I think there only could be a nois problem.
    Does somebody have experiance with eroding in Cu pipes because
    of the gas speed.
    Best regards
    Carlo Hansen
    Dec 2004
    LEBANON
    44
    854
    21
    Re: Eroding in pipe heat exchangers
    never heard of that , any information will be appreciated
    Sep 2003
    ISRAEL
    72
    4,248
    Hi Carlo,
    Its news to me.
    Maybe you get some more information from that "someone".
    Chemi
    May 2004
    61
    48
    I'v seen eroding in a flooded chiller due to the scouring action of contaminated refrigerant but never with clean gas.
    May 2004
    southern england
    69
    86
    21
    is that some kind of rotating guinea pig ?
    it's only a fridge, fix it. ;)
    Oct 2003
    5,630
    34
    I should say, every liquid circulating in a system gives friction, a pressure loss, so there must be resistance. If there is resistance, then there is somewhere a force acting on the liquid. That force can erode the inner wall of the lines.
    Aug 2001
    1,046
    of the gas speed.
    Best regards
    Carlo Hansen[/QUOTE]
    I was recently called in to look at a chiller installed in the Tower of London. The original parts of the building and the services including some magnificent garderobes, still in perfect working order, go back to Norman times and sure enough, the heat exchangers were corroded right through.
    I blame the consultant.
    ________
    Airflow
    Sep 2003
    ISRAEL
    72
    4,248
    Was it the water side or the refrigerant side?
    I have replaced quite a few shell & tube heat exchangers because lack of water treatment.
    The result was refrigerant leak but the cause was rusty buts from the water system pipes that caused the corrosion in the heat exchanger.
    Chemi
  1. Howto: Calculate coaxial heat exchangers
    By JKProSoft in forum Technical Speculations
    Last Post: 10-01-2011, 12:10 PM
  2. Refrigerant to water heat exchangers
    By sunwind in forum Technical Discussions
    Last Post: 24-06-2008, 01:40 PM
  3. frostles heat pump
  4. Poor Heat Exchangers
    By alireza in forum Trouble Shooting
    Last Post: 21-03-2007, 08:51 PM
  5. heat pipe exchanger in HVAC
    Last Post: 28-02-2006, 01:32 PM
