Results 1 to 31 of 31
Thread: chiller tank
    Apr 2010
    philippines
    chiller tank
    hi,
    Im lynark, i just want to ask how to compute the number of coils you need to used in a chiller tank. Because i have seen a water tank with so many copper tube loop together thats why i wonder how the installer or designer computed for that. assuming you already have the Cooling capacity needed.
    thank you
    11,025
    Re: chiller tank
    Heat Loss per Foot/Metre should help.
    Oct 2003
    5,630
    Re: chiller tank
    Trial and error, depends on too many variables.
    Apr 2010
    philippines
    Re: chiller tank
    hi peter_1
    so it means their is no proper computation? just by years of experience.
    hi brian_uk
    can you give some a brief sample?
    actually i'm more on designer of coldroom coldstorage. Now i want to try deeper application of refrigeration system. i want to start on this basic one. So any help is really appreciated
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    Q=h*A*(tp-tw)
    h - surface heat transfer coefficient
    A - surface area of pipes
    tp - surface temperature of pipes
    tw - surrounding water temperature
    You must know surface heat transfer coefficient (pipe/water), it's the most difficult.
    Try to find ASHRAE's articles "HEAT TRANSFER" and "LIQUID COOLERS".
    In some places will have to think ...
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    Surface heat transfer coefficient (h) depends on many factors: density, viscosity, thermal conductivity of fluid, geometrical dimensions of clad body and etc. Also coefficient depends on velocity of fluid relatively the clad body. For natural covection of fluid surface heat transfer coefficient is:
    115 - 700 kW/(m^2*C)
    For forced convection water surface heat transfer coefficient is:
    115 - 11500 kW/(m^2*C).
    There aren't general theory of finding this coefficient but there are some theories for special cases.
    Apr 2010
    philippines
    Re: chiller tank
    Quote Originally Posted by Aik View Post
    Hi aik,
    thanks for the info. So the Q is the computed heat load needed for the pipe? So by that i can find the Surface area of pipes? And how many loops needed from the header?
    thank you
    lynark
    Oct 2003
    5,630
    Re: chiller tank
    We did a test some weeks ago for a heatpump, a coil 3/8 " of 50 ft submerged in water at 12°C, Te + 1°C, R134a for standstill water gives extracts 475 W.
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    Quote Originally Posted by lynark View Post
    Hi aik,
    thank you
    lynark
    Q - is the heat [W];
    A - is the surface area of pipes [m^2];
    A=Pi*D*l
    Pi=3.14
    D - external diametr of pipe [m]
    l - lenth of pipe [m]
    The most hard poroblem is how to calculate h...
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    For a single pipe situated in fluid:
    Nu=h*D/k - Nusselt number
    h - surface heat transfer coefficient [W/(m^2*K]
    D- diameter of pipe [m]
    k – thermal conductivity of fluid [W/(m*K)]
    Re= V*D/ν - Reynolds number
    V - velocity of fluid [m/s]
    ν- kinematic viscosity factor [m^2/s]
    Pr=μ*c/k - Prandtl number
    μ – dynamic viscosity factor of fluid [Pa*s]
    c – specific heat of fluid [J/(kg*K)]
    Index "f" cover to temperature of fluid, "p" cover to temperature of pipe.
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    For corridor disposition of pipes:
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    For as on a chess-board disposition of pipes:
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    You must determine Nu, than determine h, after determine A and l.
    If angle between fluid flux and pipe differ than 90, than h must be multiplited by corresponding factor.
    Oct 2003
    5,630
    Re: chiller tank
    Aik, can you translate/calculate these formulas to see if they match my practical test?
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    I must know velocity of water and angle between water flux and pipe in your case. Also I must know disposition of pipes: single pipe, corridor or chess-board disposition...
    Apr 2010
    philippines
    Re: chiller tank
    hi aik, peter_1
    here's the details of the chiller tank i have seen.
    tank dimension: 4 ft x 8 ft x 4 ft depth
    water temp in the tank should be 10 C
    water ( stand still ) no circulation
    thank you
    Oct 2003
    5,630
    Re: chiller tank
    What do you want to cool with the water?
    We need desired temperature in and out and required flow.
    What compressor you want to use?
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    Peter_1, can you give data of velocity and angle, or may be can you give draft (domensions and connections) of your tank and volume flow of water. Then I'll try to calculate...
    Oct 2003
    5,630
    Re: chiller tank
    We submerged a standard 3/8 spiraled coil of 50 ft in water, diameter of spirals 35 cm (1.15 ft) and 2 cm (0.8 inch) from each other.
    No water flow, only agitation of the water with a small air blower at the bottom of the tank.
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    It's natural convection:
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    Formula is:
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    I don't fully understand the calculation, but I do it and result is true...
    Attached Files Attached Files
  23. #23
    sanwar's Avatar
    sanwar Guest
    Re: chiller tank
    Dear Freind,
    Could you please provide me "1 year hvac preventive maintenance schedule in ms-word formate
    Thanks,
    Sanwar
  24. #24
    Oct 2003
    5,630
    Re: chiller tank
    Sanwar, post his in a new thread, not hijacking this one.
  25. #25
    Oct 2003
    5,630
    Re: chiller tank
    Aik, I'm impressed with your result as long as you haven't changed numbers to fit the result.
    What about a 1/2" and a 5/8 " of 50 ft, same conditions?
  26. #26
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    Peter_1, if you change diameter of pipe "D" you'll get result (capacity) for new pipe with the same conditions. Also you may change length "L" of the pipe...
  27. #27
    Oct 2003
    5,630
    Re: chiller tank
    Aik, where can I find all the numbers you inserted in your formula?
    Your formula was a question which was asked many times here on RE. If we're sure about it, we then don't have to test it in real life the next time.
    What about a 3/8 coil buried in the ground? Problem will be that you will not find the right numbers for 'ground' which can be anything.
  28. #28
    Oct 2003
    5,630
    Re: chiller tank
    Aik, If I give in the correct diameter for a 3/8 pipe which is 0.009525 and not 0.09525, then I get 80 W instead of 454 W So something is wrong with the calculation
  29. #29
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    You are right, I found mistake in my calculation...Today I'll try to explane all calculations
  30. #30
    Nov 2009
    Minsk, Belarus
    171
    Re: chiller tank
    In ground there isn't convection because the ground is solid. Therefore thise calculation don't used for ground.
    I have reform the calculation...
    Peter_1, really I gave coefficient for limited space from other method of calculating, but I suppose it's correct... Also I gave operation factors at temperatures 0 and 10 C, because I don't know its at temperatures of 1 and 12 C. If you give thise operation factors at needed temperatures you'll get more precisely result.
  31. #31
    Apr 2010
    philippines
    Re: chiller tank
    hi aik and peter_1,
    I think i'm a little lost with your conversation. and thinking this is only a basic one
  1. Chiller expansion tank.
    By Helper monkey in forum Fundamentals
    Last Post: 16-11-2009, 01:27 AM
  2. Beer Chiller Malfunction
    By glennk in forum Trouble Shooting
    Last Post: 05-08-2009, 12:36 AM
  3. Co2 Tank refrigeration system
    By Prashant Kumar in forum CO2
    Last Post: 24-04-2009, 07:55 PM
  4. How an expansion tank works?
    By Raadster in forum Fundamentals
    Last Post: 25-07-2008, 02:25 PM
  5. Connecting Trane Water chiller to air handling unit
    By celtictech in forum Fundamentals
    Last Post: 08-03-2007, 06:14 PM
