26-05-2010, 04:03 PM #1
Any Fastest Way to Vacuum Water Cooled Condenser & Evaporator
Hi! Expertise Guidance Please,
I am more on Eddy Current Tubing Examination and Re-tubing work, from time to time I hear when the Condenser and Evaporator copper tubing leak it take days to month to vacuum out the water in the shell of Condenser and Evaporator.
Just wander could there be a fastest way to vacuum out the water by extracted out a few tubing and put hoses through the tube-sheet holes and with a few vacuum pumps or air ejectors to suction out the water. ??
26-05-2010, 05:42 PM #2
Re: Any Fastest Way to Vacuum Water Cooled Condenser & Evaporator
Hi Rickyccong,
Using our system, you can extract all water coming from a communication of heat exchanger. It depends on several things, but you would normally be able to finish the job in one or 2 days.
Hoshizaki Ice Maker
By Abe in forum Legal-Business-MarketingReplies: 19Last Post: 01-05-2010, 03:27 AM -
air cooled condenser size calc????
By keerth1986 in forum FundamentalsReplies: 4Last Post: 24-04-2010, 06:03 AM -
Problem with water cooled compressor
By bksingh in forum Trouble ShootingReplies: 4Last Post: 15-05-2009, 01:04 PM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM -
water cooled condensers
By aaron crimmins in forum FundamentalsReplies: 2Last Post: 22-07-2002, 04:24 PM
