Results 1 to 2 of 2
Thread: outside wall frost build up
25-05-2010, 10:26 PM #1
have a typical walk in set up, with walkin cooler and inside is the door to the walk in freezer. the unit is operating properly and maintaining temperatures. the problem is that we saw frost build up on the exterior outside wall over the winter(as it is butted up to the wall). What would cause this?
25-05-2010, 10:34 PM #2
Re: outside wall frost build up
A gap between the panel joints.
Faulty or damaged insulation in the panel.
A hole in the panel.
If it is around the door, the heater tape could be faulty.
Basically anything that lets the cold out.
Or you are in Canada, its winter, and it would have frost on it anyway
AEG frost free fridge
By tzs in forum DomesticReplies: 4Last Post: 03-01-2010, 06:15 PM -
12.5 kw wall mount air con
By Andy W in forum Air ConditioningReplies: 18Last Post: 03-10-2009, 09:35 AM -
Water leak on a daikin wall unit
By marc5180 in forum Air ConditioningReplies: 5Last Post: 27-08-2009, 07:23 PM -
re no frost keeps leaking
By emmalouise in forum DomesticReplies: 1Last Post: 08-09-2008, 09:43 AM -
frost top construction ???
By Tom Richardson in forum FundamentalsReplies: 174Last Post: 18-08-2003, 04:12 PM
