Thread: chiller
25-05-2010, 05:26 PM #1
chiller
I have a chiller emerson 1200 kw running r 407c
can we change r 134a
what we have to do , which size expansion valve required etc
regards
25-05-2010, 05:30 PM #2
Re: chiller
chiller free cooling condenser how you to clean it all we have scale
25-05-2010, 05:31 PM #3
Re: chiller
buy a new chiller if you really want 134a that much. new compressors new evaporator,new expansion valves the list goes on
25-05-2010, 08:28 PM #4
Re: chiller
Following those questions I would suggest using a suitable chiller engineer to provide the service or advice for you.
26-05-2010, 01:11 PM #5
Re: chiller
R134a pressure and Capacity are much lower than R407C. hence TXV and heatexchanger size would differ. If you use a same compressor with R134a then you would get only 70% capacity of R407C
26-05-2010, 01:42 PM #6
Re: chiller
Why would you WANT to change to R134a? :\
13-06-2010, 05:57 PM #7
Re: chiller
i think each refrigerant has properties
process chiller help
By talon771 in forum IndustrialReplies: 8Last Post: 12-01-2011, 08:42 PM -
Problems in r22 chiller design
By umeshpradhan in forum Technical DiscussionsReplies: 9Last Post: 06-07-2010, 10:39 AM -
Absorption Chiller VS Mech. Chiller
By Intern in forum IndustrialReplies: 20Last Post: 30-05-2009, 08:31 AM -
Power consumption of Chiller
By adrian116 in forum System OptimizationReplies: 7Last Post: 24-04-2009, 05:05 PM -
Trane CVHE 450 R11 Centrifugal Chiller
By albertjoseph in forum Air ConditioningReplies: 4Last Post: 06-10-2008, 03:23 PM
