Results 1 to 8 of 8
Thread: Bristol compressor issue
24-05-2010, 03:13 PM #1
I am installing a compressor Bristol model number H28A583DBL A, I am having trouble getting it started and cannot find information on the correct starting capacitor or if necessary start relays.
24-05-2010, 03:53 PM #2
Re: Bristol compressor issue
That's because the "DBL" designates three phase.
Thousands of HVACR manufacturers links! Visit: www.hvacrinfo.com
24-05-2010, 04:00 PM #3
yes, I saw that, so what do I need to get this compressor started
24-05-2010, 05:04 PM #4
Are you a HVAC tech?
Lesson one: 3 phase compressors don't require start components.
To get help we need more information.
First, describe "I am having trouble getting it started"
What's it doing?Thousands of HVACR manufacturers links! Visit: www.hvacrinfo.com
20-07-2010, 05:39 AM #5
check the model and all related details for the compressor in bristolcompressor.com, just type the model in the search area.
20-07-2010, 09:59 AM #6
first time on not sure where to post a question but would like to know if it is a big problem to by pass soft starter
20-07-2010, 09:40 PM #7
Do you have three phase power available?
If so then you need a contactor and an ON switch.
Best bet however is to get an HVAC Technician involved.Last edited by Brian_UK; 20-07-2010 at 09:46 PM.
21-07-2010, 06:43 PM #8
Sorry Slionel.
Your original post does confuse slightly.
But in fairness to you when you study the compressor schematic.
I can understand your possible confusion on the compressor phases.
The trick is the referance to the T1, T2, T3. Terminals.
See below!
Also below is the details for connecting the 3 compressor phases.
If you are still not happy then grab some assistance.
If it now makes sense as we say over here "Fill yer Boots!"
Bristol Compressors
By Chris2005 in forum CommercialReplies: 5Last Post: 09-10-2009, 06:42 AM -
bristol a-H24B22QABCA 230vac 1ph
By kfox@miindustri in forum ElectricalReplies: 1Last Post: 18-05-2009, 07:30 PM -
Bristol Compressor Corp
By shogun7 in forum New TechnologiesReplies: 3Last Post: 12-03-2004, 09:35 PM
