Thread: thermostat
    Feb 2009
    Guangzhou,China
    42
    10
    Question thermostat
    Hello,I have a question.I have an outdoor installation air/water heat pump,can I install a thermostat in the house? How to connect it with heat pump system?
    11,025
    Re: thermostat
    What is the make and model of the system?
    Split Croatia
    57
    6,151
    36
    Re: thermostat
    Yes you can and you don't need to connect it with heat pump. Thermostat will deal only with fan-coils. Heat pump has its own thermostat. It prepares water for your consumption. If there is no consumption at consumer side (fan coils), it stops. Regardless of your indoor temperature, heat pump water temperature is constant.
  1. Fridge Thermostat replacement
    By LucasAdamson in forum Electrical
    Last Post: 30-11-2009, 12:14 PM
  2. Replies: 2
    Last Post: 13-02-2009, 07:20 AM
  3. Thermostat
    By hahung in forum Air Conditioning
    Last Post: 10-01-2009, 03:49 PM
  4. defrost thermostat closed failure
    By rkmoorthy in forum Trouble Shooting
    Last Post: 02-03-2008, 10:55 PM
  5. Change BRC1D528 for X10 Thermostat
    By creible in forum Air Conditioning
    Last Post: 07-01-2008, 09:35 PM
