Thread: thermostat
24-05-2010, 10:30 AM #1
thermostat
Hello,I have a question.I have an outdoor installation air/water heat pump,can I install a thermostat in the house? How to connect it with heat pump system?
24-05-2010, 11:29 PM #2
Re: thermostat
What is the make and model of the system?
25-05-2010, 09:11 AM #3
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: thermostat
Yes you can and you don't need to connect it with heat pump. Thermostat will deal only with fan-coils. Heat pump has its own thermostat. It prepares water for your consumption. If there is no consumption at consumer side (fan coils), it stops. Regardless of your indoor temperature, heat pump water temperature is constant.
Fridge Thermostat replacement
By LucasAdamson in forum ElectricalReplies: 6Last Post: 30-11-2009, 12:14 PM -
Stubborn Thermostat Capilliary - Hotpoint Future
By Heurrgh in forum DomesticReplies: 2Last Post: 13-02-2009, 07:20 AM -
Thermostat
By hahung in forum Air ConditioningReplies: 10Last Post: 10-01-2009, 03:49 PM -
defrost thermostat closed failure
By rkmoorthy in forum Trouble ShootingReplies: 2Last Post: 02-03-2008, 10:55 PM -
Change BRC1D528 for X10 Thermostat
By creible in forum Air ConditioningReplies: 5Last Post: 07-01-2008, 09:35 PM
