Results 1 to 15 of 15
    Jul 2008
    south dakota
    10
    intermittent cooling problem?
    I have a kenmore freezerless refrigerator (mod# 60722). I bought this fridge used but in new condition, the tags were still hanging it even. I ran it in my BBQ trailer at a contest this weekend and it initially cooled to 35 degrees with the control turned to coldest setting. It shut off and doesn't turn back on until the temp is in the 60-65 degree neighborhood. I'm terribly frustrated as I went to this setup to get away from coolers and I don't want to go back. Any ideas? I'm an electrician so I kinda understand some of this but I don't know where to start. Thanks!!
    Oct 2005
    IRAN
    878
    Re: intermittent cooling problem?
    Check the thermostat first. Then check the refrigerant amount.
    Even Einstein Asked Questions
    Feb 2008
    adelaide sth.oz
    1,015
    sounds like your thermostat is out of range or its sensor is maybe in the wrong location.if its a cold plate or tube type evaporator you want to have a full frosting affect all over if you have this i would say that the thermostat is out range
    Jul 2008
    south dakota
    10
    Pardon me for not knowing alot. How would I know if the thermostat is out of range and is this a repairable problem or a replacement issue? Also, I can tell you that it has a tray underneath with maybe 4 or 6 coils running through it. This tray had a very small amount of water in it when I got mad and unplugged it. (Not because of the water but because it won't cool right. Thanks for your patience!
    Apr 2010
    Quote Originally Posted by fast_murray View Post
    Leave it unplugged a couple days with the door open. Turn the thermostat to midrange. Plug it back in and check it the next day. You probably froze it having the thermostat turned all the way down.
    Realize that a residential refrigerator isn't designed to be used as often as commercial equipment. So the box temp will be higher throughout use because it removes less heat.
    Jul 2008
    south dakota
    10
    I have had it for a few months before I used it and plugged it in the night before I left for the BBQ contest. The stat was set in the middle and it was cool to start with but then started giving me the trouble so I turned it all the was to coldest to combat that problem. Something else I thought of was my trailer was tripping the GFCI recep at the campground and the fridge may have been off and on repeatedly about 3 or 4 times until I got that problem solved. Would that matter?
    Apr 2010
    Yes a compressor can "cycle on the overload" meaning the compressor has the overload safety resetting, trying to start but opening due to the combination of heat and amperage. Unplugging it and letting it cool is how you fix that.
    I'd leave it unplugged long enough so any ice has melted, set the TS to midrange and check it a day later.
    What's the reason you got away from commercial coolers?
    Jul 2008
    south dakota
    10
    By coolers I meant a igloo cooler full of ice. It's just a drag to deal with the ice and water in your food. My neighbor looked it over and believes it to be low on refrigerant. It is running right now and said it will probably ice up if is low. What does it take to recharge it if that is indeed the problem? Thanks for your responses, its interesting to learn about different things.
    Apr 2010
    You'll need line taps, refrigerant and gauges. Repairing the leak it'll be a larger list.
    Let it run. It'll probably get down to temp.
    Jul 2008
    south dakota
    10
    When taking the thermostat apart one of the 3 spade terminals on the back of it was a little sloppy so I fixed that. It is at 33 degrees and seems to be doing ok. I looked at the coils in the refrigerator and they weren't icy, maybe just a tad frosty. I'll keep an eye on it for a couple of days and see how it is. A refirigerator in the traier is 10 times better than 4 huge coolers. Except for beer. Beer seems like it belongs in a cooler. Thanks for the help!!
    Jul 2008
    south dakota
    10
    I had a guy tell me to check the amp draw of the compressor and compare it to the rated draw. It was drawing 1.5 amps running and has a rating of 7 LRA. The refrigerator is rated at 5 amps @ 120 volts. Also, it is damn hot to the touch. Does this mean anything?
    Oct 2005
    IRAN
    878
    Yes, means lack of refrigerant.
    Apr 2010
    Quote Originally Posted by lana View Post
    Box is getting down to 33 degrees.
    He should clean his condenser coil.
    Oct 2005
    IRAN
    878
    Quote Originally Posted by sneep View Post
    If it was condenser then Amp would be higher than normal. Here Amp is lower.
    Jul 2008
    south dakota
    10
    This thing is as clean as brand new, I don't think it was hardly used. I'm going to give it a try again this weekend after fixing the thermo wire and see how it goes.
  1. Liebherr fridge sounds, cooling and LCD problem
    By bv1976 in forum Trouble Shooting
    Last Post: 03-03-2010, 11:31 AM
  2. Cooling problem with VRV REYQ24M7.
    By cool#9 in forum Air Conditioning
    Last Post: 07-02-2010, 12:20 PM
  3. Replies: 3
    Last Post: 29-10-2009, 09:41 PM
  4. LG heat pump problem
    By back2space in forum Heat Pumps
    Last Post: 01-02-2009, 11:23 PM
  5. Regulation of cooling capacity
    By npaisnel in forum Domestic
    Last Post: 08-02-2002, 11:22 PM
