Results 1 to 8 of 8
Thread: chiller selection
22-05-2010, 02:54 PM #1
chiller selection
HI Guys,
I need an overview to select a chiller for a client.At present is running at half capacity due to a fault.Also there was an old one helping it but now broke down and am looking at the idea of replacing.The chiller's total capacity is 250Kw,having 80kw as input.The other old chiller that is now broke down had an input of 36kW but no data available for the capcity,but is much smaller approx half capacity.I already had quotes from Chigo,Ferroli,and midea.Any of you guys can give any preferences to any,maybe based on reliability ?
Client in the idea of instead installing a large capacity chiller will work with 2/3 modular type.
22-05-2010, 04:11 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: chiller selection
Smaller chillers are higher priced than bigger for same total capacity.
If your plant need redundancy than go with few smaller chillers.
I could recommend Geoclima as serious and reliable chillers. They are made per your order.
23-05-2010, 05:02 AM #3
THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
23-05-2010, 05:10 AM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
23-05-2010, 11:00 AM #5
Thanks guys lot of info,will check all accordingly
24-05-2010, 07:25 AM #6
What about the MIdea guys,anyone has preference for this digital scroll chiller ? The ferrolli is another I wish to have your views.
24-05-2010, 09:45 AM #7
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Both companies doesn't have been in this field long enough to be "credible" as some older companies. But, today experts are changing their companies easily. Therefore brand is not much guarantee that some extensive research and accumulated knowledge is associated with them as some rule.
27-02-2011, 04:44 PM #8
We have installed some Midea Digital Scroll chillers and I must say that they are quite reliable. They have modular design, so one can add additional power very easily. They even succeed to heat on -10 degree Celsius. The only problem for me is the noise, which is a little bit high, but for that price you can't expect perfect quality!
process chiller help
By talon771 in forum IndustrialReplies: 8Last Post: 12-01-2011, 08:42 PM -
Chiller selection
By Ambrish_bajpai in forum NH3Replies: 8Last Post: 07-10-2010, 04:42 PM -
Problems in r22 chiller design
By umeshpradhan in forum Technical DiscussionsReplies: 9Last Post: 06-07-2010, 10:39 AM -
Help with chiller selection - 200 > 300 KW
By ec225 in forum CommercialReplies: 5Last Post: 29-08-2009, 07:02 AM -
Replacement Chiller Barrel Selection
By archibaldtuttle in forum Air ConditioningReplies: 0Last Post: 09-06-2009, 08:09 PM
