Results 1 to 2 of 2
    thetwist's Avatar
    thetwist Guest
    Taylor 754-33 Mix Temp
    I have a Taylor 754-33 air cooled soft serve unit. The mix temp is running too warm on both sides. When I reduced the temp on the left side, the "Mix Set Point" light came on. I do not get this light on the right side, when I do the same. Can anyone explain the set point light.
    I would also love to get my hands on a copy of the service manual for this machine, if anyone can download for me.
    Apr 2010
    15
    Re: Taylor 754-33 Mix Temp
    The book:
    http://www.taylor-company.com/servic...literature.htm
    You might want to call a refrigeration engineer (serviceman). As you'll see in the book worn beater bars could be the problem. You won't save a pile of money trying to fix it yourself. Taylor does have schools. Your choices not to make your problem worse by twisting on things :-) is either call a trained person or spend the dough to become said trained person.
  1. MP66 & Compressor Overheating
    By Intermez in forum Technical Discussions
    Last Post: 13-04-2010, 08:58 PM
  2. Replies: 5
    Last Post: 08-11-2009, 05:10 PM
  3. Temp. Rise at duct outlet
    By jwasir in forum Trouble Shooting
    Last Post: 10-05-2008, 04:22 PM
  4. Compressor loading, cooling, and range of operation.
  5. cold room temp & the product temp
    By smpsmp45 in forum NH3
    Last Post: 21-09-2007, 11:46 PM
Tags for this Thread
