20-05-2010, 10:28 AM #1
refrigerant dryer trips on oil pressure
Dear Sir ,
Our refrigerant dryer trips on low oil pressure after one hour from starting the system. After tripping oil level shows very low and then after some times level comes up. Pls.suggest resolve this problem.
20-05-2010, 11:17 AM #2
Re: refrigerant dryer trips on oil pressure
Oil pump, traps, refrigerant charge are good starting points.
20-05-2010, 12:39 PM #3
Here's a link to a previous post that should help you out.
http://www.refrigeration-engineer.co...ad.php?t=23829Thousands of HVACR manufacturers links! Visit: www.hvacrinfo.com
22-05-2010, 05:08 AM #4
One of the problems could be liquid flood back to the compressor even small amount.
When liquid refrigerant is present in the crankcase, it evaporates and creates a lot of vapour. This vapour blocks the oil pump inlet and oil is not circulated. When oil pressure switch delay is passed then it trips the compressor.
Check the superheat and see if you have liquid flood back.
NVQ 3 online test
By Burrah Boy in forum TrainingReplies: 7Last Post: 28-10-2009, 08:35 PM -
Newbie. Charging Refrigerant. Mitsubishi SRK 40HG.
By smoking_muzzle in forum Air ConditioningReplies: 14Last Post: 24-07-2007, 10:33 AM -
Screw compressor system losing oil differential pressure
By orm in forum Trouble ShootingReplies: 27Last Post: 27-10-2006, 03:19 AM -
Interesting Problem
By NH3LVR in forum Industrial CompressorsReplies: 13Last Post: 12-08-2006, 10:27 PM
