Results 1 to 9 of 9
    packstove's Avatar
    packstove Guest
    Which is better Ball valve or Diaphram plate
    We are modifying an existing refrigeration lines to add a temporary parallel evaporator coil loop. The idea is to isolate the coil, pump down the loop, and then remove the setup till it's needed again. once the coil is removed the system will return to normal single loop operation, but the existing connections that fed the temorary loop would still be present with only the two shut off valves from the liquid and suction lines, and possible threaded caps, from venting refrigerant into the environment. My question is, which Shutoff valve offers the best seal, ball valves or diaphram plate valves?
    Aug 2009
    new zealand
    57
    44
    Re: Which is better Ball valve or Diaphram plate
    I would use ball valves as they have less pressure drop for suction line, but as a precaution install a short section of pipe that is welded closed after the valve. It is then easy to cut this pipe and extend if you ever need to re establish the loop.
    packstove's Avatar
    packstove Guest
    Thank-you. A ball valve on the suction line does make sense, given the need to avoid pressure drop. We were hoping to not have to seal off the temporary loop with a brazed cap, but if that is th only sure way to avoid a sytem leak, then that may be the best solution. Thany you for your help.
    Aug 2009
    new zealand
    57
    44
    A good quality ball valve will not leak, brazing pipes closed is only a precautionary and saftey measure.
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by dirk View Post
    Everything leaks. Only question is at what rate.
    Aug 2009
    new zealand
    57
    44
    We obviosly still need to review our understanding of physics.
    PLEASE ENLIGHTEN US !!!!
    Split Croatia
    57
    6,151
    36
    Does this brings some light?
    Aug 2009
    new zealand
    57
    44
    Dont believe presumptions that are not based on scientific evidence.
    It is impossible to put a ball with a two inch diameter through a hole of one inch.
    It may be more accurate to say materials, welds or mechanical seals may deteriorate over time.
    The author in his opening statement contradicts himself.
    Put a drop of oil on a sheet of glass FOLLOWING YOUR ARGUMENT THE OIL IS LEAKING THROUGH THE GLASS. THIS IS IMPOSSIBLE THE MOLECULAR STRUCTURE OF THE TWO MATERIALS DOES NOT ALLOW IT .
    Split Croatia
    57
    6,151
    36
    Yo didn't got the picture. Glass bottle will leak at cork-glass junction, not thru glass material itself.
  1. Diagnosing valve plate problems
    By Dan in forum The Trail of Tears
    Last Post: 16-10-2009, 10:37 AM
  2. LEV does not open
    By Yuri B. in forum Air Conditioning
    Last Post: 19-07-2009, 02:37 PM
  3. Replies: 2
    Last Post: 06-02-2009, 07:35 PM
  4. R22 Flooded System - Trawler
    By chiefbecker in forum System Optimization
    Last Post: 07-02-2008, 11:11 PM
  5. valve plate failure
    By Andy noblet in forum Trouble Shooting
    Last Post: 04-06-2004, 08:54 PM
