    smokersuk04's Avatar
    smokersuk04 Guest
    Thumbs down HP/LP settings on R134a
    hey guys, finishing off an install of three new condensing units to three remote chillers, all identical on R134a. whats should i set the HP/LP switches to??
    11,025
    Re: HP/LP settings on R134a
    What do the manufacturers of the chillers specify for the settings?
    Aug 2009
    new zealand
    57
    44
    If there is no manufacturers specs, then depending on whether the switches provide a control or safety function they will need to be set up to accomodate the operational requirements of the chillers ( You will need the operational specs of the chiller for this specific application)
    Jan 2007
    India
    65
    I agree with Dirk. You can refer the compressor operating envelope and set LP/HP according to the lowest and highest possible operating Presures.
    Oct 2005
    IRAN
    878
    First you estimate the operating conditions i.e. evaporating temp and condensing temp.
    Set LP below the operating pressure and HP above the operating HP.
    If you set these very close to the operating conditions then you will get unwanted cut outs. Set them reasonably.
    Even Einstein Asked Questions
    Sep 2003
    ISRAEL
    72
    4,248
    High set can be 200psi.
    Low set depends on how the system stop and if there is an SV that runs parallel to the compressor or as a pump down control.
    Is it manual reset or automatic one?
    Bring more details and get better answers.
  1. R507 in an R134a compressor: any danger?
    Last Post: 21-12-2009, 12:44 AM
  2. Clogged condenser leading to no gas on R134a systems?
    By runningonavac in forum Refrigerants
    Last Post: 01-09-2009, 10:52 PM
  3. r12 vs r134a minifridges (efficiency)
    By ziddey in forum Fundamentals
    Last Post: 25-06-2009, 06:26 AM
  4. Pressure Transmitter R134a Setpoints
    By cooltrain in forum Technical Speculations
    Last Post: 28-02-2005, 09:05 AM
  5. Replies: 5
    Last Post: 01-03-2004, 09:59 PM
