Thread: walk-in layout design
17-05-2010, 01:00 AM #1
As always, best wishes for health and good business to all out there. I have more years in the field than I want to admit but everyday is a learning experience. I was wondering if , in today's world of computer info, there is software than helps design layouts of walk-in coolers and freezers. I am looking for suggestions for best positioning of evap coils in different situations, door placement, etc. I would be open to print information also if it helps. Field redesign is needed more often these days with customers buying used " I got a good deal but not exactly what I want " boxes. Also does the 10% up or down factor still apply when trying to match BTU capacity between condenser and evaporator. It seems manufacturers aren't using equipment as closely matched as before. Thanks for any help the " family " can offer. Stay safe and busy!!!
Don't leave it like you found it.....Leave it like it should be !!!
17-05-2010, 04:05 AM #2
Re: walk-in layout design
Feisty,
Follow this link and click on
Refrigeration System Design & Operation Information.
www.hvacrinfo.com
You will find the links for several load calc programs which should help you out.Thousands of HVACR manufacturers links! Visit: www.hvacrinfo.com
17-05-2010, 08:42 PM #3
Thanks, Powell, for a great site. The information is exactly what I was looking for. Again....ask the " family " and they shall answer !! Have a great day.
Design td on walk in cooler
By IMSTIEN in forum Technical DiscussionsReplies: 2Last Post: 01-10-2009, 10:18 PM -
Design, engineering and execution guides
By Josip in forum Tools and CalculatorsReplies: 6Last Post: 27-02-2009, 01:47 AM -
Efficient Water-Source Condenser Design?
By Enginerd in forum FundamentalsReplies: 4Last Post: 28-05-2007, 05:11 AM -
Replacement fo CO2 Bulk Tank refrigeration unit
By pabs_ref in forum CO2Replies: 31Last Post: 28-11-2006, 10:32 PM
