Thread: Trane chillers
    Jul 2009
    Portugal
    57
    14
    Trane chillers
    Hi , has any one done retrofit on rta series from trane using r22, models like the 430 using four screw type compressores,using 2 on each circuit.somebody want´s to use r422d on it, just wonder if anyone has done it and what kind of problems happend using mineral oil
    Aug 2003
    Netherlands
    49
    620
    21
    Re: Trane chillers
    r422d can't be used with the trane screw compressors. it's either r134a or r404.
    If it ain't broke, don't fix it!
    Nov 2009
    44
    9
    Re: Trane chillers
    Using R422d you have saturated ref. temps between -3 to -5 leaving the EEV entering the evap which will freeze the end of the tubes! Due to TRANE using remote oil separators the oil return is poor apparently the oil return is better on compressor with internal separator i.e Bitzer,Hitachi, refcomp.
    Like Lowrider said you can only use R404a or R134a best to use R404a as you can lose up to 30% capacity converting to R134a
    Best to contract TRANE to carry out conversion.
  1. Axima (Germany) chillers using Turbocor compressors
    By Boaz in forum New Technologies
    Last Post: 22-08-2011, 07:47 PM
  2. Trane water chillers
    By C J Bourquin in forum Commercial
    Last Post: 14-04-2010, 09:54 PM
  3. Those Chillers are Rubbish!
    By Grizzly in forum Chit Chat & Service Stories
    Last Post: 03-11-2009, 06:59 AM
  4. Trane Chillers
    By Freecool in forum Air Conditioning
    Last Post: 18-09-2009, 11:35 AM
  5. Trane CVHE 450 R11 Centrifugal Chiller
    By albertjoseph in forum Air Conditioning
    Last Post: 06-10-2008, 03:23 PM
