    Jul 2008
    Singapore & Malaysia
    77
    30
    Angry York Model YSDACBS3CGA Condenser Tube Sub-Cooler Freeze Rupture
    Recently done an Eddy Current Tubing Examination on York Model YSDACBS3CGA and found Condenser Sub-Cooler fourteen (14) tubes with CRACK indication. Extracting those tubes were difficult and managed to extract about 36" length and found transverse crack on the tube land location. Suspected those tubes have Freeze Rupture that Bulged the tubes.
    If forced hydraulic extraction might cause distortion to the two (2) baffle plates or breakage of tubes. If such happen than replacement of tubes could not take place. If plug all those fourteen (14) tubes on the sub-cooler what are the consequences.
    Please provide the expertise advices on such matter with highly appreciated.
    3,362
    Re: York Model YSDACBS3CGA Condenser Tube Sub-Cooler Freeze Rupture
    rickyccong ,
    It would depend on how many tubes you have as to performance drop of subcooler .
    Tubes of course can be plugged off ( in a number of ways ).
    Auckland
    74
    3,357
    38
    The condenser tubes would have been expanded internaly to stop them rattling and wearing through, so when extracted look swollen at the support sheet position. This appearance can happen if over expanded and extremely difficult to remove, or under expanded they can crack due to movement. The next problem is crevis corrossion at the support sheets due to contaminets/ acid levels in refrigerant.
    You can successfully plug 10% of total number of tubes if that is the way you want to go.
    Jul 2008
    77
    30
    Most Appreciated the Reply - The Sub-Cooler have only fourteen (14) tubes with Freeze Rupture Bulged, if plugged all the tubes what were happen that's my question??
    Never happen that the tubes are expanded internally on the Baffle Plate to stop tube from rattling and wearing. Tube plugging ten (10) allowed, if not mistaken it's under the TEMA requirement.
    Auckland
    74
    3,357
    38
    You get minimal sub-cooling, generally the sub cooling bunch of tubes are encased in a captive sheild so that all the liquid leaving condenser passes through the bunched pipes.
    What would concern me would be why the hell has that particular section of tubes leaked.
    Lack of sub cooling will derate the evaporator performance.
    Jul 2008
    77
    30
    Many Thanks Magoo - In fact the Evaporator have eight (8) cracked tubes and twelve (12) tubes with wall loss of more than sixty (60) percent (%) but extracted all tubes no problem.
    Maybe I am too expensive another vendor was engaged to extract the Condenser Sub-Cooler side the fourteen (14) tubes only managed 7 tubes out - now unable to install the tubes back, believe the Baffle Plates distorted. Now intend to plug of the 13 tubes one tube managed successfully.
  1. York Screw Model YCASO330
    By James K. Donell in forum Technical Speculations
    Last Post: 12-06-2010, 11:24 PM
  2. Heatcratf Condenser Unit MODEL
    By frostedflake in forum Commercial
    Last Post: 15-11-2009, 12:16 AM
  3. York ac model names
    By Ebenezer in forum Air Conditioning
    Last Post: 21-10-2009, 08:09 PM
  4. Condenser Temperature. HOW TO model it in 3D?
    By ruzfactor in forum Fundamentals
    Last Post: 07-09-2009, 10:57 AM
  5. excess tube length on condenser tube plate
    By onquin in forum Fundamentals
    Last Post: 15-11-2007, 06:03 AM
