Thread: Master Remote controller
13-05-2010, 07:45 AM #1
What is the advantage of master remote controller in Daikin VRV system.Why need to set the master controller.
13-05-2010, 01:39 PM #2
Re: Master Remote controller
The main advantage is that will be the only remote which can change mode from cooling to heating etc. It's usefull in the offices where You have lots of rooms and some of them want to cool some want to heat... So, whos got the master got the POWER
13-05-2010, 09:36 PM #3
As Bartolo said it gives you access from one place to the full system. also if used correctly the daikin i-touch is a really clever piece of kit for fault diagnosis,individual settings ect. check this site out once you register you can view all product info there is a manual for the daikin i-touch should tell you all you need to know.
http://extranet.daikin.co.uk/login.htm
Climate Master Controller
By Chillin4alivin in forum Air ConditioningReplies: 7Last Post: 13-05-2010, 04:22 PM -
Remote controller set temp
By sachin230 in forum Trouble ShootingReplies: 10Last Post: 30-04-2010, 07:37 PM -
Relocation Of Daikin Remote controller
By moondawn in forum Air ConditioningReplies: 1Last Post: 11-12-2009, 09:32 PM -
DAIKIN VRV Remote controller
By 2007eng in forum Air ConditioningReplies: 15Last Post: 19-07-2008, 07:04 PM -
Stiebel Remote Controller?
By Makeit go Right in forum Air ConditioningReplies: 7Last Post: 24-05-2006, 12:33 AM
