Results 1 to 1 of 1
11-05-2010, 07:59 PM #1
kindly suggest cooling system for refrugerated water circulator
hi all
i am trying to develop an water chilling circulation device for one of the instrument we supply. the basic purpose is to circulate the chilled water through a glass coil condensor which has hot vapors in it.
the specification is as follows.
there is tank which contains 10-12 liters of water solution (70% water and 30% ehtylene glycol to prevent freezing) which is to be circulated through a silicon tube of 2 meters to a glass condensor which has evporating hot vapors in it and then back to the tank.
we have to maintain a temprature of -10 or -20 degree Celcius.
kindly suggest me the compressor type and capacity along with motor wattage, coil thickness and length and all other things which u think are important as basic configuration for the device.
i had seen in an uk based same device they have implimented rotary condensor, but when i asked to various engineers they said it is not successful so go for a basic one.kindly suggest the best possible which i can implement as its very urgent for me
Daikin fault codes
indoor split ice
By SkyWalker in forum Air ConditioningReplies: 5Last Post: 07-09-2009, 04:51 PM -
water cooling coil
By Lc_shi in forum FundamentalsReplies: 11Last Post: 02-09-2006, 08:45 PM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM
