Thread: Assigning a equivalent R-value.
10-05-2010, 08:22 AM #1
How would one go about assigning a equivalent R value to a material. Or find the U value and go from there. I have a rude lab set up where I am measuring the heat rise of a pound of water by ten degree F under a material I am testing, and doing the same with know insulating materials, and then basically stacking insulation on top of the insulation I started with until the time it takes to raise the temp ten degree matches the time it took with the material I am testing. It is a "thermal barrier" material. The person I am doing this for will argue that it is not a radiant barrier, but to me it is just a play on words. However and anyway, I am doing this because I find it very interesting to do, and a good project. Any input would be appreciated.
10-05-2010, 10:16 AM #2
Re: Assigning a equivalent R-value.
surenuff
Q=A U K
U=W/m2K
Q=W
W=J/s
U=1/R...
It's a simple case of mathematics where you need to transpose the formula with respect to time. I would help more but I am not familiar with imperial units.
18-10-2010, 06:23 PM #3
Q = Amē * Wh/mē * K
VB Q = 1mē * 0.3Wh/mē * K
Q = 1 * 0.3W/h * 1 = 0.3W/h
Looking for oil equivalent to POE 160
By Rigo in forum Technical SpeculationsReplies: 6Last Post: 01-09-2009, 03:48 PM -
Sourcing a modern equivalent to old USA Copeland compressor
By weeksy in forum Industrial CompressorsReplies: 7Last Post: 15-05-2009, 03:46 PM -
Equivalent Lenght table
By RODRIGO BR in forum Refrigeration BooksReplies: 2Last Post: 23-11-2007, 04:16 PM -
Equivalent length for fittings
By harsen in forum Technical SpeculationsReplies: 12Last Post: 11-04-2007, 05:13 AM
