Results 1 to 13 of 13
28-03-2005, 01:38 AM #1
Where can I get a 2/3Hp compressor?
Hi, does anyone know where I can get a 2/3Hp compressor from?
I was going to get one from here but someone on the XS forums has said they've overcharged him and he still hasn't received the compressor yet.
If anyone could provide some links, I'd be most grateful.
I live in the UK by the way.
28-03-2005, 08:03 AM #2
Re: Where can I get a 2/3Hp compressor?
Ohhhh..........is IoM in the UK.
Go to the nearest wholesaler if you need a new one or dismantle one from a broken fridge.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
28-03-2005, 04:52 PM #3
Yeah the IoM is a little island in the UK, so getting to a Wholesale is a bit tricky to be honest. Plus, we're not allowed to take stuff once it's been dumped, so getting a compressor from a dumped fridge isn't easy either. Besides that, I would have thought most of the compressors in fridge/freezers will be around 1/6Hp.
29-03-2005, 03:57 PM #4
Hi Jimi,
Guy and Lesly Becker sends their regards to you and Rose.
Small world isn't it?
Chemi
29-03-2005, 07:40 PM #5
Originally Posted by chemi-cool
29-03-2005, 07:58 PM #6
Sorry Jimi,
I was told there only one Builder called Jimi on the Isle of Man.
About your question, can you get the model No. and make, refrigerant used.
It has to be small commercial unit or a very large American fridge.
Chemi
21-07-2005, 10:18 PM #7
You could try HRP they go that small in several makes. May not be cheap and probably wont be in stock........... www.hrponline.co.uk
Another source would be Hawco
21-07-2005, 10:39 PM #8
http://www.srw.co.uk
cheers
richard
22-07-2005, 03:12 AM #9
Originally Posted by rbartlett
wesmaxWes Maxfield
14-08-2005, 04:55 AM #10
Dean and wood or HRP, depending on what you want.
22-08-2005, 06:01 AM #11
Originally Posted by Jimi
wesmaxWes Maxfield
22-08-2005, 06:49 AM #12
Try Climate Center aswell
13-11-2005, 02:58 PM #13
koolfreeze are fine for compressor prices.
can overfilling/overcharging damage a compressor?
By fredjchavez in forum Trouble ShootingReplies: 10Last Post: 12-02-2009, 11:30 AM -
Compressor pumping efficiency
By shogun7 in forum FundamentalsReplies: 0Last Post: 25-02-2004, 11:50 PM -
One Half of a Part Wound Compressor Motor is Burnt
By aygul in forum Trouble ShootingReplies: 2Last Post: 25-08-2003, 11:11 AM -
Compressor failure...... cause
By herefishy in forum Technical SpeculationsReplies: 8Last Post: 06-12-2002, 01:15 AM -
Starting a compressor, and receiver questions.
By DaBit in forum Technical SpeculationsReplies: 9Last Post: 24-08-2002, 12:37 PM
