    Isaac-1's Avatar
    Isaac-1 Guest
    Refco Royal 2 Vacuum Pump Oil?
    I bought a slightly used Refco Royal 2 vacuum pump (I know its not a Yellow Jacket, etc, but the price was right). Anyway after I bought it I started looking for some information on this pump online, I can't find much other than it is a small 2 stage pump rated down to 50 microns , but did find a reference in their catalog that shows to use their DV-06 series oil with this pump (as well as their discontinued RD-4/6/8), where as all their current pumps use a DV-44 series oil. Now for my question, does anyone know what the difference is between these oils, and can you suggest an oil that is easy to find in the U.S. for this pump?
    thanks
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Refco Royal 2 Vacuum Pump Oil?
    There are a few types of oil, almost the same.
    Just google for vacuum pump oil and see for yourself whatever you need.
    Isaac-1's Avatar
    Isaac-1 Guest
    My problem is I don't know what is different about the older Royal 2 and RD series pumps. A pdf of a 2007 Refco catalog I found online lists both both the DV-06 oil (for the older pumps) and the DV-44 oil (for use in the current model pumps) so the DV-44 oil did not replace the DV-06 oil. My problem is all the suppliers I found that list the DV-06 oil are outside the U.S. and can find no cross reference for DV-06.
    Ike
  1. Vacuum Pump Questions
    By position1 in forum Fundamentals
    Last Post: 08-10-2009, 02:33 AM
  2. Vacuum cleaner as a vacuum pump
    By chemi-cool in forum Chit Chat & Service Stories
    Last Post: 14-08-2009, 10:11 PM
  3. vacuum reduces when vac pump is isolated
    By bill1983 in forum Fundamentals
    Last Post: 04-08-2009, 08:00 AM
  4. Troubleshooting a vacuum pump and gauge set.
    By Old Codger in forum Fundamentals
    Last Post: 08-08-2008, 05:13 PM
  5. inverters pulling vacuum
    By bangoman in forum Air Conditioning
    Last Post: 05-02-2008, 09:12 PM
