08-05-2010, 12:24 AM #1
Holmes Show, 05/07/10: It's raining so they cut Refrigerant Lines...
Tonights' Holmes Show, 05/07/10; Raining so A/C guy says we'll cut the refrigerant lines, showed cut lines on video, remove old condenser & come back tomorrow when it's not raining & install the new condenser.
Didn't even show them sealing off the open lines, - or briefly explain their procedures the next day.
It only takes a few minutes to remove the old condenser the next day when it's not raining.
They don't say they are removing the old refrigerant lines & replacing them along with a new matching evaporator coil.
So, we're supposed to guess concerning what they are going to do in order to make it right...
They never mention purging with & then flowing dry nitrogen at under 3-psig while brazing, then leak testing & then proper deep micron evacuations if a new R-410A moisture sensitive system.
Why not briefly "Show & Explain Doing It Right Procedures," concerning an A/C installation?
Why do we have to guess concerning what he is going to do the next day "To Make It Done Right."
Forget the excuses, there are none, I know, I was a TV producer & director in college.
If you don't show the HVAC "Do It Right Procedures," you just defeated the central purpose & theme of the show. - udarrell
08-05-2010, 11:00 PM #2
Re: Holmes Show, 05/07/10: It's raining so they cut Refrigerant Lines...
You get so worked up whenever you watch that show.
I think perhaps it is time to stop looking at it to keep your blood pressure down.Brian - Newton Abbot, Devon, UK
16-05-2010, 03:44 PM #3
I don't get worked up when watching his shows.
I actually like his shows, it's only when the HVAC sub-contractor comes on the show & never shows the proper procedures, - that I protest a little.
Are we HVAC contractors supposed to keep, - doing it RIGHT Secret? I think so...
The right kind of consumer education will increase your business, because they are motivated to be proactive toward improving home & HVAC efficiencies.
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
'Holmes On Homes' HVAC Make It Right
By udarrell in forum Air ConditioningReplies: 8Last Post: 06-05-2010, 03:59 PM -
MHI FDCA400HKXRE4 Tech Info Please
By L.JT in forum Trouble ShootingReplies: 5Last Post: 23-08-2008, 11:00 PM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM
