Results 1 to 10 of 10
    Jan 2005
    N.Ireland
    48
    177
    Angry Toshiba A/C Compressor size
    Hi All.
    Was at a supermarket today which had a fault with a toshiba A/C unit he said it was very noisey last night but when i got there today it had knocked off the mcb for the unit.
    Checked everything out and the comp is gone but the rating sticker has been cut off the compressor so there was a identical unit beside it so i took the covers off and the label has the top cut off as well.
    I phoned the toshiba helpline and the man said they cut them off in the factory and i wud have to get on to there suppliers (so they can rip us off)
    Can anyone help me with the size of this compressor
    Model RAV-464AH8-PE
    Serial 24880009
    R407c
    Thanks Chris..
    Oct 2001
    Nottingham UK
    5,667
    Re: Toshiba A/C Compressor size
    Hi Chris
    Give these guys a ring and they will give you the part number
    24-hour Technical Helpline - 0870 843 0333
    Sep 2003
    ISRAEL
    72
    4,248
    Hi Chtris2005,
    I think you can work out the size from here.
    http://www.toshiba-aircon.co.uk/tech...20BH%20SBH.pdf
    Chemi
    Mar 2005
    Newcastle upon Tyne
    52
    Hey Chris I would be worried about who took it in the first place 'cause it may happen again
    Jan 2005
    N.Ireland
    48
    177
    Very funny Crit71
    I thought you would of had some better information than that for me.
    Its nice 2 no i can count on you when i am in bother lol
    chris..
    Aug 2001
    1,046
    Quote Originally Posted by Chris2005
    Hi All.
    Model RAV-464AH8-PE
    Serial 24880009
    R407c
    Thanks Chris..
    Toshiba should be able to give you the part number. As I recall, it should be a Copeland scroll and they are a special for Tosh, so you are unlikely to get one 'off the shelf'. You'll have to go through their distributors - they won't sell spares direct.
    Additionally, Tosh offer a 3 year warranty as standard in the Uk and that unit is in warranty.
    From the serial number it was made in Plymouth in August 2002.
    ________
    M engine
    ireland
    1,451
    41
    Guys
    I have a toshiba MAR F 81HTM 8E, compressor has been condemned by toshiba service(inverter driven) due to noisy operation(sounds like an aircraft engine when under load), does anyone have a technical manual like the mitsu service tech manuals, want to test run unit and check for gas etc., also would any of the uk suppliers ship a compressor over here with warranty?? Quoted 3500euro for replacement compressor!
    Alec
    Mar 2005
    Birmingham U.K.
    70
    54
    hi Al
    For the Toshiba compressor for the MAR -F81 HTM8E try H.R.P. at Bury St Edmunds on 01359 270888.
    They are Toshiba agents and i am sure they will be able to send you a compressor plus a service manual especially if you are spending money with them.
    For me the Toshiba VRF has been a reliable unit compared to Daikin VRVs
    In the last 10 years only changed about 2 compressors. main problem has been with the discharge solenoid coils in the multi boxs which go open circuit and cause the compressor to trip out on high pressure.
    The compressor does get noisy if it is running at 400psig discharge pressure !
    You say the inverter compressor is noisy how about the D.O.L. compressor ?
    I have a service manual which i can photo copy for you, if you cannot get one from H.R.P. or direct from Toshiba.
    but it is dated 1996 so i think it would have been superseeded by now.
    please let me know
    regards
    bob
    ireland
    1,451
    41
    bob
    Thanks for the info, will contact them as soon as i get a few minutes!! Compressor was linked out from inverter with the same noise, but the high discharge is something that wasn't checked by toshiba, if i get the service manual i'll test for that.
    Thanks again
    Alec
    Feb 2005
    Aberdeen
    48
    168
    Hi Bobjob
    Also when the hot gas solenoids burn out in the multi-boxes they can also burn out the pcb which is a bit of a pain as this then puts the cost of repair right up.
    Daikin VRV are more reliable. Wouldn't you agree?
  1. Toshiba Digital Inverter range?
    By Slim R410a in forum Air Conditioning
    Last Post: 18-10-2010, 02:45 PM
  2. Toshiba Warranty
    By gwilliamson in forum Air Conditioning
    Last Post: 17-05-2006, 05:59 PM
  3. Replies: 1
    Last Post: 19-02-2006, 12:08 AM
  4. toshiba ac blowing t5a fuse
    By silentbobt in forum Electrical
    Last Post: 16-02-2006, 08:17 PM
