    May 2010
    W.Yorkshire
    31
    Ws150 ws-150 ITE Scales question
    Do you know how to use ws-150 scales? As I have opened mine and quite simply can't weigh a bottle with an unknown amount of gas in. Is there a simple solution?
    3,856
    Re: Ws150 ws-150 ITE Scales question
    Hi Aircon467,
    I'm not familiar with those scales. When i want to know how much refrigerant is in a bottle, i turn on the scale and wait till they say 00.0, then put the bottle on which lets say weighs 12.46kg, stamped into the bottle is the tare weight (empty weight) which is in this case 9.7kg.
    So 12.46 - 9.7 = 2.76kg of refrigerant in the bottle.
    When charging a system put the bottle on the scale, connect your hose, then press the zero button. As you charge the system, or indeed fill the bottle, the scale will display the extra refrigerant in or out. Its important not to move your gauges or hoses as this can add or subtract quite a few gramms to your measurments.
    Jon
    Jun 2009
    Columbus Ohio
    55
    169
    15
    I always set up so my gauges are laying on a block of 2x4 and there is a little slack in the hose..
    this way I can crack my gauges on and off and it doesnt bias the weight of the scale...
    -Christopher
  1. Oil Capacity Question
    By Z2TT in forum Transport
    Last Post: 02-01-2010, 08:24 PM
  2. Replies: 1
    Last Post: 02-06-2009, 04:01 PM
  3. UK, Asylum and Immigration Act - Question
    By Brian_UK in forum Legal-Business-Marketing
    Last Post: 27-05-2009, 11:33 AM
  4. Refriferation cycle question
    By ozmecheng in forum Fundamentals
    Last Post: 26-03-2008, 10:38 PM
  5. Urgent, Kirchoff question
    By Peter_1 in forum Fundamentals
    Last Post: 20-01-2004, 03:12 PM
