    Apr 2010
    Scotland
    5
    Changing defrost heater
    Hi Can anyone shed some light on changing a defrost heater on a Aeg Santo 75348kg. I can't see how to get at it with limited movement of the evaporator.
    Many thanks in advance
    May 2008
    U.K.
    73
    Re: Changing defrost heater
    Rather you than me!! Is this one with evaporator on the ceiling of the freezer compartment? If so, once you've removed the cover, there should be enough movement to pull evaporator forward and allow it to drop. I'm assuming unit is fully defrosted?
    Apr 2010
    Scotland
    5
    Thanks for the reply.. and yes it is!
    I can drop it all down a little but i'm worried about the copper pipe feeding the evaporator getting damaged. Looks like the whole lot fan, evaporator, heater and sensors are all part of the same unit that has been put together then installed.
    Nightmare!
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. maytag fridge activation of new controller
    By jdrefrigeration in forum Domestic
    Last Post: 09-03-2010, 12:00 PM
  3. RS21 Main Defrost Heater Help Please
    By elnno in forum Domestic
    Last Post: 28-06-2009, 01:14 PM
  4. Whirpool defrost heater
    By frozen fred in forum Domestic
    Last Post: 27-01-2008, 06:41 AM
  5. No Power for Defrost Timer Motor
    By kln in forum Domestic
    Last Post: 21-01-2008, 08:22 AM
