Thread: Daikin L1 Fault??
04-05-2010, 08:10 AM #1
Daikin L1 Fault??
Hey Everyone,
Iv got a daikin unit, an RZP100K4VA, that is showing an L1 fault code... i have got absolutely no information on this nor can i find any....
Im hoping someone on here might be able to shed some light??
When i turn the unit on, it takes about 15 mins or so before it goes out on fault.... however in that time the compressor or condenser fans wont run, no action at all from the outdoor unit, even though its set on 16c on cooling and room temp is 25c
thanks in advance guys
04-05-2010, 01:01 PM #2
Re: Daikin L1 Fault??
Hi there,
L1 fault is outdoor PC failure, if you have another unit the same near by try swapping over pc's and taking it from there?
Hope this has helped.
07-05-2010, 11:03 PM #3
be careful as if there is an L1 fault it has failed for a reason, before changing the board check the compressor resistance and make sure it is not down to earth.
Also check that fan motors before changing.
Daikin VRV U4 FAULT
By leegally1983 in forum Air ConditioningReplies: 14Last Post: 30-11-2010, 11:49 PM -
Daikin r407c 2 pipe vrv ja fault code any offers?
By Contactor in forum Air ConditioningReplies: 11Last Post: 28-07-2009, 01:26 AM -
Daikin Cassette Fault
By symon22 in forum Air ConditioningReplies: 5Last Post: 23-05-2008, 06:19 PM -
UA Daikin Fault Code
By jedi in forum Air ConditioningReplies: 2Last Post: 23-07-2007, 01:44 PM -
u4 fault on a Daikin inverter
By phil17 in forum Air ConditioningReplies: 39Last Post: 05-02-2007, 02:41 AM
