Results 1 to 1 of 1
Thread: Fujitsu ASTA34LCC Fault Code
04-05-2010, 12:43 AM #1
I'm trying to trouble shoot a Fujitsu ASTA34LCC - I've hard rest the unit a couple of times, on power up in heating mode the fan does not blow and the unti flashes the green light (timer light) 5 times, then repeats.
Had problems with the unit since day 1 - the last intermittent fault (different error code) went away after a refrig top up, couldn't find a leak but couldn't get the code to repeat.
Can someone assist with this error code?
ckw_79
Fujitsu AOTR18LCC Fault Code
By ferret82 in forum Air ConditioningReplies: 6Last Post: 16-11-2009, 10:13 AM -
Fujitsu ASTA09LCC error code
By exotiic in forum Air ConditioningReplies: 9Last Post: 19-08-2009, 03:56 PM -
Sanyo Text Back Fault Code Service
By techguy in forum Air ConditioningReplies: 1Last Post: 04-02-2009, 06:57 PM -
mitsubishi city multi fault code
By robin r33 gtr in forum Air ConditioningReplies: 5Last Post: 05-11-2007, 10:23 PM -
UA Daikin Fault Code
By jedi in forum Air ConditioningReplies: 2Last Post: 23-07-2007, 01:44 PM
