03-05-2010, 12:55 PM #1
CDX Aircon with Heatpump-Diagnostic Codes
Installed CDX Aircon with Heatpump 18H53R230C3(a4) which ran briefly when started then stopped responding to controller after 15 minutes evaluation & trialing.
Powered off. Waited a minute. Powered on. Got a list of diagnostic codes from indoor unit.
Relay clicks on, fan motor runs, louvre moves.
All symbols light up + 88 on display
52 with '2' flashing
CC
12
9E
CC
Shuts down, fan motor stops, louvre self parks, display goes off.
Looks like an orderly start-up with selfcheck that fails and then the unit shuts the system down.
R410a system, appears gas tight though is gassed to 7m but pipe run is around 11m [possibly the root of the problem].
Would be nice to know what the codes are though!
Not in manual, supplier doesn't know but emailed manufacturer [China]. No answers after a week. No web or other address to contact.
A full list of this unit's diagnostic codes would be appreciated if anyone has one.
Little point in manufacturing a unit with self diagnostics if the codes are not released to suppliers & techs, unless, of course, they're industry standard.
04-05-2010, 09:02 AM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: CDX Aircon with Heatpump-Diagnostic Codes
That is same as Galanz. I think they are manufactured by Chigo. Try search their site.
http://www.chigogroup.com/en/servicemanual.asp#
04-05-2010, 02:46 PM #3
Thanks very much for info. Spot on. Talked to supplier this morning who advised unit is a Galanz and I'm pursuing diagnostic codes from their chigogroup.com site.
I'll publish the codes here if/when I can get hold of them, to help any others who run into the same trouble.
Thanks again
04-05-2010, 08:55 PM #4
This unit has same code as Galanz Kudo Single
Shinco Error Codes - E4?
By orangeroost in forum Air ConditioningReplies: 41Last Post: 04-02-2012, 01:17 AM -
Troubleshooting for Daikin Aircon CTK25FVEN
By JCTK in forum Air ConditioningReplies: 19Last Post: 05-06-2010, 07:18 PM -
Diagnostic Fault Codes
By nike123 in forum Trouble ShootingReplies: 12Last Post: 03-06-2009, 10:08 PM -
Aircon in Room
By Nigler in forum Air ConditioningReplies: 1Last Post: 12-03-2009, 08:02 PM -
crazy 3rd-world idea: aircon from small fridge
By lsemprini in forum FundamentalsReplies: 71Last Post: 29-05-2008, 01:10 AM
