30-04-2010, 11:07 PM #1
does any one where to get these's ice machine pumps from?
hi all, i,ve looked at an ice machine and the water circulation pump is seized, but the problem is, there is no name on the machine, no serial or model number, it looks like a whirlpool k40 water pump but with a bigger motor and with a bigger connection for the out water,and the water pump is built in to a plastic plate 9inch by 3 inch situated on the back, its only a small ice machine like a k40 but it has a curtain were behind the water sprays up to the evaporator and makes round shape ice.i think its about 10 to 15 years old (maybe)
so if anyone has any sejestions to what type of machine it is or where to look for that type of water pump it would be much appresiated
01-05-2010, 03:18 AM #2
Re: does any one where to get these's ice machine pumps from?
at a wild guess, try the supplier and importer.
02-05-2010, 04:49 AM #3
Here in the states we have a pump company called Little Giant. They make condensate pumps but also have a great ice machine pump universal to several models. Kit includes several discharge adaptors and is capable of field modification to some level. I carry 1 just in case and have gotten out of a lot of trouble late at night and weekends. Beckett also makes a great pump for the same purpose. Good luck.
Don't leave it like you found it.....Leave it like it should be !!!
Ice Block Machine: Hoping to start an Ice Factory. Please Help!!
By promise1 in forum CommercialReplies: 15Last Post: 02-01-2011, 01:26 AM -
Air source heat pumps
By marc5180 in forum FundamentalsReplies: 15Last Post: 10-06-2010, 06:34 AM -
Energy efficiency of air-source heat pumps with variable speed compressors
By BoardMan in forum FundamentalsReplies: 14Last Post: 27-01-2010, 02:32 AM -
Manitowoc Ice Machine
By crazycohiba in forum CommercialReplies: 3Last Post: 27-08-2009, 05:19 AM -
Cattabriga Ice Cream Machine
By Abe in forum Trouble ShootingReplies: 9Last Post: 26-04-2003, 01:06 PM
