    tobe5052's Avatar
    tobe5052 Guest
    DX ground loop heat pump
    Anybody have any experience or comments on the Earthlink system for heat, a/c, and hot water? Any known problems with the proprietary Active Charge Control device?
    Any info appreciated!
    Any other similar systems in use?
    Oct 2003
    5,630
    Re: DX ground loop heat pump
    If you do a search on this forum, you will find a lot of information (DX coil, GSHP, ...)
    Apr 2009
    Panacea, Florida
    87
    Find a copy of Design/Data Manual for Closed Loop Ground-Coupled Heat Pump Systems, published by ASHRAE. Written by J.E. Bose, J.D. Parker, and F.C. McQuiston, Oklahoma State University, 1985.
  1. compressor for wind powered heat pump
    By tomwol in forum Technical Speculations
    Last Post: 12-11-2011, 01:05 PM
  2. Basics or is it?
    By Fett in forum Fundamentals
    Last Post: 10-09-2009, 01:45 AM
  3. Greenline ground loop heat pump
    By Chris2005 in forum Heat Pumps
    Last Post: 22-10-2008, 11:32 AM
  4. Domestic VRF heat pump?
    By electronicsuk in forum Heat Pumps
    Last Post: 30-10-2007, 07:53 AM
  5. Single Duct...... AC or heat pump?
    By Argus in forum Heat Pumps
    Last Post: 03-10-2007, 11:29 PM
