Thread: Cold Room
01-05-2010, 03:32 PM #1
Cold Room
Currently, I am working on refrigeration and do study’s at the same time to expand my knowledge. The more I know, the better service I can give to my clients.
Could you assist me on the following questions please?
How do I know what size compressor and coil do I have to use on different sizes cold rooms or freezer rooms? For example: My client asked me he wanted a freezer room, length 10m, width 6m, height 2.4m. This size is just an example.
How do I know what size of liquid line and suction do I have to use on the above mentioned?
How do I know at what settings do I set my LP / HP switch to on the above mentioned?
What is the purpose of the solenoid on the liquid line? I assume it’s to cut off the gas, and then build up the pressure to the LP /HP switch, which is switching off the compressor. Is there any other reason for the solenoid? For example: Is the cold room switched off by the thermostat and do you still need the solenoid? If yes, why?
I would really appreciate it if somebody can help me out with the correct info.
Thanking you in advance for your time and help.
Regards,
Chris van der Walt
South Africa
E-Mail: cc.vanderwalt@gmail.com
01-05-2010, 05:39 PM #2
Re: Cold Room
Hi bro. Vanderwalt, if you're into ammonia refrigeration design and installation I strongly suggest that you should have your own Refrigeration handbook, codes and standards. The IIAR ammonia ref. piping handbook, ASHRAE handbook and ASME std. B31.5 would really help you in expanding your knowledge.
As basics, to be able to know the compressor or condenser equipment size, you should first compute your Net refrigeration capacity for a specific room or system(Total room heat loads + Product load). From this, you can also properly select the size of your evaporator cooler.
The liquid line solenoid valve is typical in all evaporator valve stations. This solenoid valve closes when your rm. temp reaches its required temp. as called by the rm. thermostat or temp. sensor. It will open as the temp. inside the rm. rises again. Nowadays, evaporator valve stations are also controlled by a PLC or SCADA system packaged with the whole ref. system.
I hope I gave you an idea. Good luck in your career.<"No one is so smart, they just stay with problems longer and use their imagination">
01-05-2010, 05:40 PM #3
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Cold Room
http://www.refrigeration-engineer.co...ad.php?t=19701
http://www.refrigeration-engineer.co...ad.php?t=24673
Buy some ASHRAE books.
If LP is used as PUMP-DOWN control than it is set according to working pressures/temperatures.
http://www.ra.danfoss.com/TechnicalI...chapter_03.pdf
Research on Google with PUMP-DOWN keyword.Last edited by nike123; 01-05-2010 at 05:51 PM.
01-05-2010, 05:52 PM #4
Re: Cold Room
Thanks for all the info!!!!!!!!!!!
Blind Cold room specs help
By frostedflake in forum Trouble ShootingReplies: 5Last Post: 13-03-2009, 01:49 AM -
Cold room floor
By Andy AC in forum CommercialReplies: 8Last Post: 19-02-2009, 04:26 PM -
Cold room panels
By LLCooLJ in forum CommercialReplies: 6Last Post: 07-04-2008, 04:18 PM -
cold room
By CHILLED4 in forum Trouble ShootingReplies: 5Last Post: 16-11-2007, 11:44 PM -
Installation of cold room
By Josip in forum Legal-Business-MarketingReplies: 12Last Post: 12-03-2006, 09:20 PM
