    Apr 2010
    United States
    Looking for a Small, Open Drive, Scroll Compressor
    Hello:
    I need a small (2kw) open drive scroll compressor for a heat pump application. Any suggestions?
    3,853
    Re: Looking for a Small, Open Drive, Scroll Compressor
    The only open drive scroll i can think of would be for auto air con, google sanden scroll compressor and see what you can find.
    Jun 2009
    Columbus Ohio
    55
    169
    15
    I use Sanden 508 Automotive compressors all the time for testing in an open-drive environment.. most of them will handle a 1.5 ton load easily... there is also I believe a Sanden 708 which is a 2-ton compressor often fitted to Limousines and Busses...
    being automotive it is pretty Beefy.. I would stick to running R-134a or a blend or an HC similar as the design of the compressor wont handle continuous use under High head pressures... trypically the High pressure cut-offs in automobiles are at 375-400 PSI and the comoressor is usually rattling pretty good at that point...
    it is very easy to fit lines to them as well..
    -Christopher
    Apr 2010
    United States
    Thanks, cadillackid. It looks like the Sanden TRSA09 Scroll would work for me.
    Could you please describe how you fit lines to them?
  1. copeland scroll durability
    By Third_techtrio in forum Technical Discussions
    Last Post: 23-01-2010, 04:47 AM
  2. [Autocascade] Only a project ATM
    By before in forum CPU Overclockers
    Last Post: 07-05-2009, 11:13 AM
  3. Wanted - open drive compressor and other bits
    By SteveDixey in forum Industrial
    Last Post: 17-02-2006, 05:55 PM
  4. Scroll compressor
    By Abe in forum Technical Speculations
    Last Post: 25-03-2003, 12:47 AM
