Results 1 to 14 of 14
    May 2008
    170
    You need this cable in your life
    Hello,
    Check out this cable
    http://tpwcc.com/flexishield.html
    SY cable is no good for outdoor installations and all of you still using it should be ashamed of yourselves (Yes, I am wagging my finger)!
    If you are using standard flex then you are a degenerate!
    SWA is an absolute b@*@*@d to work with and most of you are not earthing it properly!
    This flexishield cable is expensive but saves masses of space and time. If we all start using it then our suppliers will stock more of it and it will revolutionise AC wiring.
    It complies with BS8436.
    Check it.
    Aug 2007
    Sydney
    52
    1,083
    23
    Re: You need this cable in your life
    Very cool R1976
    We use a lot of this type of cable in controls wiring but in the smaller side. I am looking forward to the day when this type of cable is the norm. When/if I build my house I will use this type of cable too - mainly for its safety. By shielding electric and magnetic fields with the sheath and ground which interfare with our biological cellular communication reducing cancers. I wonder why the electricity supply lines don't use this type of cable for transmission? would there be more losses or is it just down to cost considering average transmission losses are in the order of 50%.
    ireland
    1,450
    41
    Do the likes of CEF stock this?
    al
    Scotland
    327
    I need that cable like I need a scrotal leech.
    Oct 2007
    manchester
    5,639
    45
    pirelli fp200 gold 110quid for 100m or 60quid for ventcrofts equivelent which u cannot terminate properly due to the core insulation is so poor u can strip it with ur fingernails
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by contactor View Post
    i need that cable like i need a scrotal leech.
    scrotal leach
    Apr 2009
    israel
    778
    Quote Originally Posted by R1976 View Post
    Hello,
    Check it.
    Hi :
    looks nice ,check out the site below i have been using them they got em all!!
    http://www.helukabel.de/usa/index.php?lang=en&func=2p&parentid=41
    THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
    May 2006
    Sussex
    362
    SY cable is no good for outdoor installations.
    I believe the problem is that the clear PVC sheath on most (if not all) SY-cable has little UV-protection. If used outside it can degrade quickly and the PVC sheath eventually splits (not good).
    However, some manufacturers claim their SY-cable is suitable for outdoor use, so presumably it has adequate UV-protection (something to verify before you buy). That might also be why some installers tuck the interconnect SY-cable behind the fridge pipes to keep it out of sunlight.....and I thought they were just trying to make the install look nice.
    May 2008
    170
    Quote Originally Posted by Makeit go Right View Post
    They tuck it behind to hide it!
    The shameless scoundrels!
    I am interested in your comments on SY that IS suitable for outdoors, where can it be bought?
    I did like using SY but found it went brittle and then filled with rainwater after about one year.
    Check out these links,
    http://www.voltimum.co.uk/news/8747/...d-outside.html
    http://www.ryanairconspares.com/racs...ble-p-139.html
    http://www.theiet.org/forums/forum/m...threadid=27819
    http://www.allowe.com/Humor/PowerCableSex.htm
    May 2006
    Sussex
    362
    Hi, there, R1976.
    The regular SY cable that's not so good for outside sunlight is the clear sheathed variety, whereas you can get hold of BLACK sheathed SY cable, which is fine for outside (and looks nice running on top of the black armaflex insulation).
    I managed to get hold of a distributor's leaflet which says: "Black SY cable is protected against UV damage therefore making the cable ideal for outdoor use."
    One distributor that sells it is:
    Alpha Wholesale,
    Unit-10 Goudhurst Road
    Marden, Kent TN12 9NW
    Tel: 016 2283 1836
    Fax: 016 2283 2488
    Email: sales@alphawholesale.co.uk
    {No connections}
    Feb 2008
    IRELAND
    70
    what about nyy? not shielded or armoured but suitable for outdoor use and has a very tough thick black sheath http://www.eland.co.uk/electrical-ca...y-j-cable.html
    nevgee's Avatar
    nevgee is offline Veteran Poster I am starting to push the Mods: of RE
    May 2006
    Yorkshire
    72
    417
    Hmmm? you go on about uv damage but how many of you consider the fact that standard pipe insulation such as Armaflex etc is not uv stable.
    It doesn't take too many months before the whole run of pipework insulation on roofs and open to sunlight starts to crumble to dust.
    Does anyone of you make allowance for this .. do you provide protection against uv radiation ?
    Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
    Split Croatia
    57
    6,151
    36
    May 2006
    Sussex
    362
    We're drifting a bit away from the original post/topic concerning the safety of using correct electrical cable and now discussing..... insulation.
    Possibly insulation deservs a new/separate post?
    There is armaflex paint to deal with UV, if the installer is concerned enough to tackle it. And as mentioned you can get solar armaflex insulation http://www.pipelagging.com/advanced_...19fa86&x=0&y=0 (not much different in price than regular). However, none of the regular stockists stock it so it doesn't have a chance.
    But, the insulation is not really in the same league as cable, is it? If the cable splits and water gets in there is a real safety issue. If the armaflex degrades the worst is some drips on the ground, some loss of temperature, and a chance for a maint contractor to earn a few pounds in repair work -- not exactly big potatoes.
  1. SUPCO Logit temperature datalogger cable missing
    By coldkeeper1 in forum Supermarket Refrigeration
    Last Post: 27-09-2008, 12:26 AM
  2. SY Cable
    By Celcius in forum Air Conditioning
    Last Post: 26-11-2007, 11:18 PM
  3. Wire Capacities
    By Latte in forum Electrical
    Last Post: 21-10-2006, 06:44 PM
  4. 50 Ways to Improve Your Life IN 2006
    By Lc_shi in forum Chit Chat & Service Stories
    Last Post: 30-12-2005, 12:29 PM
  5. Rules of life
    By chillin out in forum Chit Chat & Service Stories
    Last Post: 13-10-2005, 02:16 PM
