Thread: Tandem Compressors
29-04-2010, 02:51 PM #1
Tandem Compressors
First A/C post so take it easy
First of all I am an turbine engine engineer but have interest in all things mechanical.
I was wondering why The Tandem compressor sizes on my newly installed AC system (Ruud UASL-060JEC outside and RBHM26J inside) were chosen. Compressor "A" is +- 36,000 BTU and compressor "B" is +- 24,000 BTU. Compressor "A" is all ways stage 1 and "A" + "B" is stage 2. Is this just to simplify the control recognizing the limits of the TXV range? It would make more sense to me to have three stages, stage 1 "B", stage 2 "A" and stage 3 A+B. In our climate (SW Florida) we have about two months at the beginning of the cooling season (March-April and two months at the end of the cooling season (Sep-Nov) where the temperatures are moderate but the humidity is 80% +. I would think that if the expansion valve could be controlled to use the lowest capacity, it would enhance the moisture removal without excessive cooling.Last edited by Hitech; 29-04-2010 at 04:03 PM. Reason: error
29-04-2010, 05:40 PM #2
Re: Tandem Compressors
Hi :
- what type of unit are we talking about?
- most units expecially the new ones have an exv that can adjust to either size as needed
- i dont think your unit configuration falls under the category of tandem comps!
- are your compressores inverter type, or regular ,or one of each?
THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
29-04-2010, 05:53 PM #3
Well it has two scroll compressors in parallel with separate controllers. a single condenser and a single evaporator. The is a 5 ton split system.
This is typical current high efficiency design in the good old USA, stage 1 is 67% stage 2 is 100%. The compressors are single phase 230 volt 60hz.Last edited by Hitech; 29-04-2010 at 10:03 PM.
question about compressors and AC units
By sale in forum Trouble ShootingReplies: 1Last Post: 24-04-2010, 01:17 AM -
How to prevent spare compressors (in storage) from developing leaky seals?
By Z2TT in forum TransportReplies: 8Last Post: 17-02-2010, 04:05 PM -
Compressors - screw or reciprocating?
By Josip in forum Industrial CompressorsReplies: 18Last Post: 27-01-2009, 10:36 PM -
New types of Refrigeration Compressors
By adjohnson208 in forum New TechnologiesReplies: 3Last Post: 03-07-2008, 07:35 PM -
Do we have some expert in replacing compressors
By Zahid in forum Air ConditioningReplies: 2Last Post: 01-07-2008, 07:59 AM
