Results 1 to 2 of 2
    Nov 2008
    canada
    64
    Preventive maintenance
    On H.P. NH3 systems when is the best time to tighten bolted flange components such as hot gas v/vs,strainers and so forth when they are hot or cold?
    3,355
    Re: Preventive maintenance
    I would say ambient temp ie 20 deg C and the rest will work itself out .
    Lube on bolts also very helpful in getting bolts tight .
  1. Multi deck maintenance
    By Andy AC in forum Commercial
    Last Post: 29-07-2009, 01:44 AM
  2. Maintenance Manager Software
    By brian_chapin in forum Industrial
    Last Post: 04-03-2008, 06:13 AM
  3. small split maintenance charges
    By chillymatt in forum Air Conditioning
    Last Post: 20-01-2008, 07:44 PM
  4. Air conditioning maintenance procedure
    By Andy T in forum Air Conditioning
    Last Post: 27-05-2006, 06:57 PM
  5. maintenance
    By Servicefrigo in forum Technical Discussions
    Last Post: 27-01-2005, 04:02 PM
