    Mar 2010
    pakistan
    44
    Effect of oversized condenser?
    Q no 1) What will be the effect if an oversized condenser condenser is used. I mean a 2Ton condenser is used in a 1TON system????
    Q no 2) Secondly what will be the effect if a 2Ton compressor is used in a Ton system??
    Apr 2009
    israel
    778
    Re: Effect of oversized condenser?
    Quote Originally Posted by mianrizwan View Post
    1. low head pressure ,system will work unstable
    2. very hi head pressure,system will work unstable if the evaporator is small then you will be working on low suction as well- liquid slugging
    3. this is info offhand there will be many more symptomes!!
    Mar 2010
    pakistan
    44
    oky thanks
    Mar 2009
    KZN, South Africa
    64
    2,212
    Goshen :
    Can you perhaps expand more on this part - oversize condenser? The low head-pressure part, I understand.
    Where does the instability come from? Are you thinking on terms of driving pressure-difference across the orifice & possible hunting?
    Sep 2005
    The system will be overcondensing resulting in an unstable supply of liquid at the tev inlet.
    Low head pressure without a c/fan spped controller can contribute to low pressure trips certainly on cold days.
    A 2 ton compressor on a 1 ton system will result in very high discharge pressure and overheating of the compressor providing it doesnt trip the HP safety first.
    Are these theoretical questions or are you building a system like this?
    Apr 2009
    israel
    778
    i hope not,!!
  1. Replies: 2
    Last Post: 08-06-2010, 11:12 PM
  2. Condenser Temperature. HOW TO model it in 3D?
    By ruzfactor in forum Fundamentals
    Last Post: 07-09-2009, 10:57 AM
  3. Capillary Tube Characteristics
    By Chef in forum Fundamentals
    Last Post: 10-03-2009, 01:03 PM
  4. Air Cooled Condenser Leakage Problem with R-404A
    By RADHAKRISHNARAO in forum Technical Discussions
    Last Post: 30-07-2008, 12:21 PM
